Basket clogs
SOURCE: Grounds overflowing
if you use less grounded coffee and still does it the water go trus no problem the trouble is dirty filter if its metal one or were the coffee exit just before going in the carafe let me know thanks for using fixya pierre
SOURCE: Coffee grounds overflow out of basket into top of coffee pot.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
SOURCE: Our office has a VPS series coffee maker. We pour
try ask a specialist about that matter. or to the store where you bought it. I guess you must read again the manual. Hope this link shall help you with your concern.
http://www.coffeemakerwizard.com/
SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Make sure you are using BUNN brand cupcake filters, not the shorter-sided generic variety. Also, inquire with BUNN about an optional attachment for some models that will slow down the rate of water flow. Lastly, ensure that you are not over-filling the basket with grinds. There is an upper limit to how much a coffeemaker will hold, and some people try to compensate for weak coffee by adding too much.
