Question about GE Washing Machines
Grab it in a choke hold and yank straight up. It should pop right off. There are plastic tabs that hold it to a coupler. Let me know if it gives you trouble.
Posted on Jan 28, 2013
SOURCE: WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
Posted on Jan 18, 2008
SOURCE: drawstring tangled under agitator on an older GE washing machine.
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Posted on Sep 21, 2008
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Posted on Dec 15, 2008
SOURCE: Agitator is slipping- GE model WJRR4170G top load washer
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Posted on Feb 20, 2009
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
Oct 25, 2016 | GE Washing Machines
Nov 28, 2012 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
1 First you must determine the brand of washing machine you have.
Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
Jun 03, 2012 | GE Washing Machines
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Mar 12, 2009 | GE Profile WPSR3100W
Feb 21, 2009 | GE Washing Machines
Dec 03, 2008 | GE WBSR3140DW Top Load Washer
Sep 11, 2008 | GE WHRE5260E Top Load Washer
153 people viewed this question
