Question about Bose Acoustimass 15 System
Bose acoustimass 15 no sound out of left and right speaker
My sound system has worked fine, up until I turned everything using my harmony remote, and my son had cranked my receiver all the way up. Now, I don't have any sound coming out of my front right and front left speaker. I have switched the speakers with the rears, and I still get sound from the rear channels, but not the front right and left. I think that something is blown in the subwoofer, and I am hoping that it is something simple like a fuse. Is there some sort of surge protection in the subwoofer? My system has a date on it from 1998, and I provide the serial number if that would help.
Posted by Fabian Valinskas on
  • Fabian Valinskas Jan 31, 2013
    Turns out that my son, who also cranked the volume, had also changed the A/B selector switch to "B", when my speakers are on the A side. I had probably 3.5 hours in diagnosis, and chatted online with bose. Kudos to Bose to help me figure out that no sound was coming from the receiver, and that the receirver was most likely faulty.... Turns out it was just User error. I am posting this in hopes that if someone like me has the same problem, that they would read this and check the A/B switch. Thanks for all your commments though.
  • timoithy costa May 03, 2013
    Dear Fabian, tnx a lot for your answer, and question :) i had the same problem and tnx to you everything went fastwer... see u and good luck!
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Posted on Aug 05, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Posted on Oct 08, 2008
Anonymous
  • 51 Answers
SOURCE: bose acoustimass 15 series 1 channel loss
Sounds like you may have a blown output transistor or chip, which generally show no external signs of damage. This would take an experienced technician to find and fix, and I commend you for knowing to check the speakers, receiver and cables through substitution! If you're handy with a soldering iron and can find the parts, try replacing the output transistors or chips in question. These are what usually fail in audio power amplifiers - also check any power resistors for opens - some of them are designed to act as fuses to protect the more expensive components.
Posted on Dec 29, 2008
Anonymous
SOURCE: BOSE ACOUSTIMASS SYSTEM 15 SUBWOOFER - NO POWER
I will try as best I can... There is no light on the unit. There is a two position switch, that's your on/off switch located on the botttom of the unit next to the pwr cord input... When the straight lined side is pushed down the unit is energized. When you pwr up the unit you should hear a light bump, not a cracking noise. There is a fuse on the main input/output board that is pretty easy to pop and swap.
Posted on Feb 10, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Posted on Apr 28, 2009
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Kenwood VR-405 receiver
Try cleaning the little window where the
IR detector is on the receiver, and clean
the transmitter led on the remote also
If that does't work then it may
be a defective IR circuut problem
IR led or resistor or possibly IC
Dec 22, 2007 | Audio Players & Recorders
Tip
Harmony remote is not controlling Dish Network device.
Hi. For most Dish Network devices, you will have to ensure that the remote address is set on 1 in order for it to be controlled by the Harmony remote.
To reset your Dish Network device to remote address 1, you can do the following:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button.
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
That should get the device working with your Harmony remote.
Hope it helps.
Sources: http://support.logitech.com
on Mar 10, 2010 | Audio Players & Recorders
I aquired Bose Acoustimass 15 surround sound through home purchase. Hooked wires up to reciever and hdmi to tv and i got nothing. my question is, how do you turn on the sub? just plug it in?
Hey Any chance you have the Acoustimass 15 II or III? The first Acoustimass 15 has a switch. The II and II models turn off and on when it receives a signal from the source you are using. Amplifier, ect. All you need to do is make sure everything hooked up correctly and plug it in.
Aug 02, 2014 | Bose Acoustimass 15 System
Trying to sync my dish remote to a Harmony remote but it doesn't sync. Have a Dishdvr 522
That should get the device working with your Harmony 700!
Hope it helps :)
Mar 10, 2010 | Logitech Harmony 700 LCD Remote Control
Hi -- I have a Logitech Harmony 676.We installed a new component ( a Bluray player ), and had to create a new account. So we went through all the steps, and now we can't get any sound. Also, the TV doesn't...
First you need to figure out why your not getting sound. For the following don't use the remote. Turn everything on manually. Set the TV's input to the source you want i.e. DVD, input1, inuput2, etc... While viewing that source manually turn up the volume on the TV or receiver. If using the receiver, toggle thru the inputs untill you here your program. Write down the combination of equipment and there input settings. Bottom line we need to get your hardware working and understand the settings before we start working on the remote. Once the hardware is working you can then program the Harmony with the correct settings. If your hardware is not getting you audio please send me more information concerning your setup. TV type, Cable box, direcTV Reciver. I need to understand your setup before I can help you troubleshoot your system.
Hope this helps.
Jan 27, 2010 | Logitech Harmony One Advanced Universal...
The lcd has turned off, and won't turn back on..everything else works fine, on harmony 659 remote.
Try the following troubleshooting steps:
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting.
2) Ensure you have the latest version of the Harmony Remote Software (7.6).
3) Update the firmware on the Harmony Remote. The following link shows how to complete this task:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this:
a) Remove the battery from the Harmony Remote.
b) Press and hold the power button while reinserting the battery into the Harmony Remote.
c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
If still not working - contact Logitech and tell them you completed these steps
Jan 05, 2010 | Logitech HARMONY 659 Remote Control
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Bose Acoustimass 15 System Logo
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
