While watching tv programs the DVD mode seems to come on and disrupts the television after about 10 minutes of viewing.
SOURCE: GPX TV AM FM DVD
Hi, Go to the website of your satellite provider and access the remote control portion and they should have codes for the different items the remote can control. If you have problems, send me the satellite info and controller model and the tv model and I'll see if I can find the info you need. Jay
SOURCE: how do i connect my GPX dvd player to my hd tv? I have Direct TV also.
I also have a GPS DVD Player and Direct TV. On the back of the TV there are slots for AV1 and AV2, I chose AV1. The yellow cable is your video.When placing the YELLOW in the video I noticed the pic was Black and White. After changing it to the slot marked Video Y the color came back. The white and red are audio. I put the WHITE in Audio L and the RED next to it in Audio Pr. Granted I am using a Phillips TV but the concept is the same. Hope this helps. If you don't have sound, switch the position of the Audio (red and white) cables.
SOURCE: connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
SOURCE: NEED CODE FOR GPX TV/DVD COMBO
The remote control code for the GPX TV/DVD combo player is: 20699 or 20769 (Direct TV)
Also try: 0699 or 0769
http://www.gpx.com/owners_manuals/TD730B-IB.pdf
SOURCE: my GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
