grunaire GSI091HXB / GSU091HXB 9,000 BTU 16 SEER Heat Pump Inverter Logo
Anonymous Posted on Jan 27, 2013
Grunaire unit trips breaker immediately when we try to reset it.
We tried replacing the breaker, but it keeps tripping. The unit is about three years old and has not had any other problems. We are currently using it as a heating unit. The temps are low twenties at day and low single digits at night.
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jan 27, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
4066
Points
60
Very likely a defective compressor. while there are other things that could cause the tripping, 90% of time it will be the compressor. generally, it will not be cost effective to repair the system if it is.
  • Anonymous Jan 28, 2013
    Thank you for the response...not good news, but we will have it checked out.
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
1helpful
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Breaker Trips Immediately
Have a short in unit. Need to check continuity of each component to ground to determine where short is. Also make sure breaker is good.
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
I have two Siemens arc fault breakers that after a year have now started to trip whenever I plug something in. I can plug in a light, a TV, a modem, an iron and they trip immediately My bedrooms have...
Do you have anything plugged in? If they keep tripping with nothing plugged in I would call a electrician to troubleshoot or replace the breakers. They may still be under warranty from Siemans.
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
2helpful
3answers
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
1helpful
2answers
Breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Top grunaire Heating & Cooling Experts
Paul Carew
john h
Are you a grunaire Heating and Cooling Expert? Answer questions, earn points and help others
