Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
- Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
- Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
- Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
- Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
- Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
