Microsoft Windows XP Home Edition Logo
dalvrl Posted on Jan 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove searchnu - Microsoft Windows XP Home Edition
Brian Sullivan
Level 3:
  • Microsoft Master 27,725 Answers
  • Posted on Jan 28, 2013
Brian Sullivan
Microsoft Master
Level 3:
Answers
27725
Questions
Helped
5669750
Points
79191
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
Uninstall searchnu
You can remove the searchnu.com from the browser in following ways:
Remove the Searchnu associated items from the control panel.
Repair your browser settings and perform ccleanup on your system.
**You can also avail our technical support by visiting our website: http://www.vtechsquad.com
Uninstall searchnu
Follow the removal instructions here:
http://deletemalware.blogspot.com/2012/04/remove-searchnu-uninstall-guide.html
Then scan your computer with AdwCleaner and Malwarebytes.
How to get rid of searchnu ?
Go to Control Panel
Go to Programs
Then go to Programs and Features
Find Searchnu in the list
Click on Searchnu and then go to the top and uninstall
Make sure you also go to Tools in your browser and Add-on's and remove searchnu from the list as well.
Go to control Panel
Go to Programs
Go to Uninstall Program
Click on the searchnu program and then either go to the top and click uninstall or right click and uninstall
Then go to your browser that you have the searchnu in and go to tools
Go to Add-on's and delete searchnu
I can't remove searchnu
Here's a very straightforward guide on how to get rid of searchnu. Please follow it very carefully. Good luck!
How to delete searchnu
Uninstall iLivid and related applications. Then follow this removal guide on how to remove the remnants of searchnu. Good luck!
Cant remove searchnu
You may try going to the Store of Google Chrome, then go to section called Installed and then select it and click x
If that did not help, try going to Tools - Settings - Extensions - and try removing it from there.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
