Question about Gateway FPD1975W 19" LCD Monitor
Main menu on the lower right hand side keeps popping up
Menu keeps popping up and everything I do to try to solve it hasn't worked.
Posted by Mary Scimeca on
Sheldon Haines
    Problem Solver:
  • 11 Answers
Sounds like your menu button on the monitor is stuck in the pushed in position. See if that is the problem and use a needle, q-tip with alcohol to pop it back out.
Posted on Nov 01, 2013
How do i delete some messages in viber but keep other messages
swipe to the left of the message ( main message menu ) a box will pop up on the right hand side to delete or save.
Aug 10, 2014 | Apple iPhone 4S
How to get rid of main menu on my hanns-g hw173d that keeps on popping. help me to solve this please
It's not a very good solution, but you can open the monitor and disconnect the button-panels plug on the mainboard. Afterwards the buttons don't work any more (surprise) but the control panel disappears.
Feb 07, 2012 | Hanns.G Corporation HW Computers &...
My monitor menu on my samsung syncmaster 731n keeps popping up on the screen and I cant get it to stop
this is a normal condition for that kind of monitor, because it was design only with Samsung syncmaster 731n in which the old model. The reason why it always popping up is because it always adjust the setting of the images. The only way to solve this problem is if this menu appears again you only press the reset button there at the left side of the power button.
Aug 31, 2011 | Samsung SyncMaster 720N/731N
My Sims 3 keeps freezing! I spent 60 dollars on that game!!!!!
It's possible that you computer specks are not up to par for the game. Not all computers are build the same.
Check it on this web site http://www.systemrequirementslab.com/cyri/
You also can try lowering the setting by following these steps
  • Launch The Sims 3.
  • Click on the blue '...' Options menu on the lower left-hand corner.
  • Click on the 'Options' menu item.
  • By default, the Graphics settings tab should be the first tab open.
  • Slide all the Graphics sliders to 'Low' under the 'Graphics details' section.
  • Click on the blue check mark button on the lower right-hand side of the Options window to save your changes.
  • Re-start The Sims 3.
May 30, 2011 | Video Game Consoles & Games
My text is too small, can,t enlarge it
Hi, 5barndore,
If you're using Windows 7 this should solve your problem:
-Click on the start button in the lower left hand corner
-Click on "Control Panel" on the right hand side of the menu that pops up
-Select "Appearance and Personalization"
-Under "Display", click "Make text and other items larger or smaller"
-Select "Medium" and then click apply
-You will need to log out and log back in
-If this is still too small, repeat the process, this time selecting "Larger"
Hope this helps!
-endercoaster
Apr 21, 2011 | Computers & Internet
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
My menu screen keeps popping up and won't go away
If you are comfortable, take the back off and on the lower right hand side, locate the control IR pickup board. (The Remote sensor). Follow the ribbon cable and relocate that wire away from the inductors on the X board.
You could also try a software update. That may fix the problem.
Feb 01, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Main menu inviting to take a tour on how to adjust the monitor keeps popping up uninvited.
Your screen settings are not optimized for that monitor, most Gateways (to h*&%) come with a drivers disks for the monitors put that in and run setup for the monitor.
May 02, 2009 | Computers & Internet
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Gateway FPD1975W 19" LCD Monitor Logo
562 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
