Bose wave music cd #2 will not eject Cd is stuck in side cannot get it to come out .
Posted by Joyce Jefferson-Bell on
Jam22
I tried all of these nothing worked so I had the system on its side pressed eject while trying to insert another cd. That worked.
Posted on Aug 01, 2021
Argospete
    Genius:
  • 1,035 Answers
If I was you,contact bose.
Posted on Jan 27, 2013
5 Related Answers
Anonymous
SOURCE: bose acoustic wave music system
I have the same problem: ready to throw it out and get a new one
Posted on Dec 09, 2008
Anonymous
SOURCE: a disc is in the Bose Wave system and will not play or eject
Unplug the system. Turn the entire unit upside down. The CDs will eject. After I tried this (found it online somewhere), it worked fine for about 2 months. Now it suddenly turns on by itself and ejects CDs (creepy). But at least the original problem was solved.
Posted on Apr 08, 2009
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
Posted on Jun 12, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
Anonymous
SOURCE: I have a bose acoustic wave,single disc model
Had the same problem. Mine the cd drive got out of alignment. Sorry to say the fix is to have it replaced. BOSE will do this for about $150. Typically this includes the one year service agreement, a full system "tune up" and a one year warrenty.
Call BOSE and they will take care of you.
Posted on Oct 02, 2009
I cant insert a CD into my Bose Wave Music System. I think there is a CD stuck there. How do I get it out?
It is very difficult to remove a stuck disc and may require removal of the cabinet to get inside the works. Best to take it to a qualified service shop where they can do it for you.
3answers
Cd stuck
Did you try resetting it?
A CD is stuck in my bose system How do I get it out?
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
2helpful
What's your problem?Bose wave system cd doesnot eject
Contact the nearest authorised service center for Bose. CD loading mechanism has been struck. You have to open it. It is a skilled work.
10helpful
2answers
Update CD Disc is stuck in wave music player, it didn't update anything for the multi changer and it will not eject. Stuck in "Loading" cd mode
Have you tried unplugging the player, waiting several seconds and then plugging it back in?This may reset the euipment and cause it to eject the update disc. Be sure to wait when it says wait. Do not force anything. You may damage the unit.Is this an entirely new system? If it is, find your manual and paperwork and call the company support number immediately.
3helpful
Hope it may helps;
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • 0helpful
    Cd stuck
    unplug the unit and as you plug it back in start pressing the eject button in one second intervals as it powers up. This should command it to eject before it tries to read the disc.
    Ekse
     Grubhead
    Grubhead
