KitchenAid KGRA806PSS Gas Kitchen Range Logo
Posted on Jan 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchenaid KGSS907 oven door locked after self clean mode, what I must do?
Owen Shaw
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 142 Answers
  • Posted on Oct 07, 2013
Owen Shaw
Expert
Level 2:
Night Owl:
Answers
142
Questions
0
Helped
28755
Points
336
Thermostat at the back/rear might have blown.
Is the oven still working?
Then the door actuator motor may have failed.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Feb 02, 2009
SOURCE: KitchenAid oven shut down during self-cleaning
I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
Anonymous
  • Posted on Apr 07, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Anonymous
  • 242 Answers
  • Posted on Apr 14, 2009
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Anonymous
  • Posted on Mar 30, 2010
SOURCE: Oven went dead in self clean mode and the door
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
hazscreenid
  • Posted on Aug 31, 2010
SOURCE: Kitchenaid KGSA906PSS00
I recently encountered this issue after trying "self clean" on my KitchenAid oven for the first time. I wish I had read these forums and simply avoided the feature. KitchenAid was, of course, completely unhelpful since my warranty was expired. This is the first they've heard of the problem; perhaps search engines are prohibited within the KitchenAid community and they are unable to view the complaints of thousands of other customers as I have... but I digress.
The solution was straight forward: Don't worry about the locked door for now and pull the oven away from the wall. Safety first: unplug your oven and turn off your gas valve. Now remove the back panel. There is a sheet metal strip near the top of the oven that must be removed before the back panel comes loose. With the back panel removed, look for a circular device with a blue and white sticker on it and the part number: 8300802. This is a thermal fuse that blows when the oven gets too hot (apparently "too hot" is a subjective measure as normal operation during self clean will cause this issue). You can check it with a multimeter if you have one... a failed fuse will have a high resistance. To ensure this is your only issue and to immediately unlock your door, adventurous types can bypass the fuse by connecting the two wires that connect to the fuse and hold them together with some electrical tape. WARNING: never operate your oven in this manner. This is a quick test to verify resolution of the issue; not a permanent fix. Apply power to your oven and presto, your door will unlock and your front panel will illuminate.
Now, use the aforementioned search engine KitchenAid has never heard of and search for your new fuse: 8300802. I got mine for $34... you can probably find it for cheaper but my patience was wearing thin by the time I got to ordering a replacement part.
Oh, and one last step: never ever under any circumstances use the self clean feature. Do not take the easy route like I did: get your Brillo Pad and your Easy-Off and get dirty, you lazy bum.
Self oven clean. When we set it to clean and set the time it locks the door, starts for 8seconds and then shuts off and will try to restart 2 more times
Repair - Dead oven after self clean mode, blank display ...
? 9:38
www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen ... How to fix a Kitchenaid
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
How to fix an F5 E1 error code on Kitchenaid oven model # KEBS107?
This is what I used on my Kitchenaid Superba maybe it will work on yours also.
Hold the "oven light"
then push the "CLEAN" button
and then the "START" button.
Wait until "Door Locked" shows on screen.
Press "Cancel/Off" (Upper Oven) wait until "Door Locked" turns off.
The oven F5 E1 is now fixed.
Kitchenaid KGSS907 oven door locked while in self clean mode
It locks so you dont open it during the cleaning cycle. It gets very hot so it burns everything stuck fast to a crisp. after cycle is over and temp drops it will unlock. dont worry about a small amount of fire as long as it dosent get too big it should be fine. Might make alot of smoke though.
Can't unlock oven door
Put the oven in self clean mode, it will lock the oven, once the self clean mode has started turn the self clean mode off, give it a second and the oven should turn off. Same thing just happened to me and it worked.
9helpful
2answers
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
1helpful
I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Code comes F5E7. This has happen before after we have ran the self cleaning mode. We managed to get it out of that mode. Please help The oven part will not come on
The oven thinks the door lock will not unlock after the self clean operation. This could be:
1. Door lock motor problem - did the door unlock after cleaning?
2. Unlatch-sensor switch on the door lock mechanism - switch or wiring may be bad, or switch out of alignment. Try opening and closing the door a few times to see if it clears (if it's not locked).
3. Control board not sending the proper unlock signal to the lock motor.
We repair control boards at www.fixyourboard.com.
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Top KitchenAid Kitchen Ranges Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
