Question about NetGear R6200 WiFi Router
Iphone won't connect to Netgear R6200
The router kinda has two connections: *******, and *******-5G. ******* stopped working and *******-5G is still working. The problem is that *******-5G won't appear on my IPod Touch 4G, my brothers IPhone 3G and my mom's IPhone 4 but will appear on my dad's Macbook and IPhone 5 and my parents' two IPad 3. It's been a week and the connection still doesn't work and my dad doesn't even try to repair the connection so I want to do it myself :) Can you please help me? Thank you!
Posted by Yoyama on
Justin
  • NetGear Master
  • 2,072 Answers
Yeah that's a dual band router. Which means it operates on 2.4Ghz and 5Ghz. Sounds like some of your devices only work on the 2.4Ghz. So make sure it is enabled in the configuration.
This video will show you how to get to the config screen on your router.
Posted on Jan 27, 2013
5 Related Answers
Anonymous
SOURCE: Problem connecting Ipod touch to WiFi
What password are you entering on to the ipod touch?
Posted on Jan 05, 2009
mohana sundaram
  • 173 Answers
SOURCE: Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Posted on Nov 28, 2007
Anonymous
  • 854 Answers
SOURCE: My NetGear WGR614 v1 stops broadcasting and needs to be repowered
I suggest you do a firmware upgrade. But in doing this, you will loose the settings on your router. You have to reconnect all you devices on the new settings.
Please follow this steps:
2. Download this link ftp://downloads.netgear.com/files /wgr614v1_1400.zip
3. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
4. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
5. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
6. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Setting the router:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username ([email protected]) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Sep 18, 2009
Anonymous
  • 17 Answers
SOURCE: flashing wifi symbol on netgear wireless router. iphone help
Hi
I will try to help you out with this....
Might be you tried to cinnect with the network many time thats why its keep on disconnecting,
you can delecte all the netwoks that you have in you 3G Iphone and try to connect fresh, if its still give you the same error then you need to change the channel on the router if still it wont connect I suggest you to change tehw ireless settings on you router and reconnect all the computer and you Iphone again with the new network...
Steps are below before you change any settings on teh router i would like to inform you that you will loss your wireless connection till you reconfigure and reconnect you computer with the new network again........
open the internet explorer on your wired computer
type in 192.168.1.1or you can type http://routerlogin.com
, it will prompt you for user name and password, the user name will be 'admin' and password will be 'password', make sure you type it in small case
click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I hope above mention will resolve your concern.....
Thanks
Harmeet :)
Posted on Oct 28, 2009
anandg27
Anand Gupta
  • 1272 Answers
SOURCE: iPhone keeps dropping wifi signal on Netgear DG834G router.
Hi, please perform the below steps to configure settings on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on WAN setup from left menu. Check the box for 'Disable Dos Protection'.
6. Set the MTU size to 1400. Click apply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 08, 2010
How do I keep my netgear r6200 from dropping internet?
What is it connected to for Internet access? How is it connected?
Feb 23, 2015 | NetGear R6200-100NAS AC1200 802.11...
My range has been significantly reduced after installing the recent new firmware. I used to connect to Netgear 88 but now I have to use Netgear 88 5G. Is it the 5G or the new firmware?
Go back and reload the firmware if that solves it you are good to go if not revert back to factory firmware and then post a note on Netgears site,could be a bug in their firmware.
Oct 26, 2013 | NetGear N600 Wireless Dual Band Router
Netgear n600
Does your IPAD or your computer show the Netgear88 as an available connection. If you are using windows 7 you should be able to look at your "network and sharing" page. Then click on "connect to a network" (2nd one down). When click on that another screen should open up showing which band your computer is connected to. It should also show the OTHER band as well. It will also show the signal strength for both the Netgear88 channel and the Netgear88 G channel. If that information is there and the signals are good then the problem is in your IPAD. You may need to check to see if it needs to be updated as well.
Oct 26, 2013 | Computers & Internet
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
Can't connect i phone 4 to the router
1. In your iPhone, go to Settings>General>About. Then, scroll down to "Wi-Fi Address". This is your MAC address. This you will need in order to authorize your phone in your Netgear page (which usually looks something like ***.***.X.X (where "X" are numbers)).
2. Log in to you Netgear page.
3. On the blue left panel of the screen, click on "Wireless Settings". A new page comes up.
4. Click on "Setup Access List".
5. Click on "Add" to enter the require info needed for your phone to gain access to your network.
6. On "Device Name" I entered "iPhone". This name is irrelevant for i named my iPhone differently and using just "iPhone" worked. So enter whatever name you wish, but keep it simple.
7. Now, on "Mac Address" (the single most important info here) enter the number you obtained in Step 1. Make sure you enter it with the colons (:).
8. Add and apply, and wait for the blue bar at the top of the screen to do its thing. It will take only a few seconds to update the network.
That's all! Connect and enjoy!
Nov 30, 2011 | NetGear DG834G Router
NetGear R6200 WiFi Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
