SOURCE: New LHW0050PQ--Worked first 5 cycles, now won't start..Help
I took mine apart this night. The top comes off by removing two torx screws from the top-rear and lifting at the rear and lifting in the rear until the front edge slides out of the sheet metal. Regarding the door switch. It appears to cut the power to to the control PCB so if you can turn on the power and press the plunger on the door switch (located on the right side above where the door latch catchs) and the control panel lights up - it isn't the door switch. My local "service tech" has been waiting for a replacement door assy for (4) weeks. I finally got frustrated and took the unit appart myself. Mine will not spin or move the drum in any way but does run the pump. I will try setting at different locations in the cycle and turning the power on and starting it. It definately is not the door switch - what a waste of time.
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
SOURCE: Agitator Not Working
My Hotpoint VBXR1090B top loading washing machine quit spinning during the rinse cycle and also quit agitating.
The water filled up and drained just fine --no leaks.
Here's how I fixed it in 5-minutes.
Tools:
Procedure:
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
