Your gas is not being burned completely. And you are getting code 11.
These may be 2 different problems, or more, related to gas supply, incoming air, venting, electric, dip switches, product defect ... which does not leave much off the table.
Code 11 is can also be wrong gas, wrong gas pressure, incorrect grounding, wrong size gas meter, and/or gas regulator.
Gas supply:
The tankless unit has BTU rating on label.
Get a hold of gas company to look at meter sizing, and pressure, to see if the meter is correct size for whole house line demand. And gas company may red tag your water heater. For good reason, until a professional validates installation.
If home has other gas appliances, and meter is undersized for
additional demand from tankless, then that can damage some appliances.
Dip switch and gas type:
Ask
Rheem if your model matches the type gas you have: Natural gas, NG,
and propane, LP, are different, and some tankless models work with
either type gas depending on dip switch setting.
Dip switches and altitude
Ask Rheem if the dip switch setting on
your model matches altitude above sea level. Different altitudes can
require different dip switch settings.
If untrained person messes with dip switches then that is a risk.
Electric:
Check 120V outlet for correct polarity ... and full voltage with 80% rating on tankless nameplate ... and check grounding to unit, ...
and electric line should be dedicated, and main box should have whole
house surge protector to avoid power surge knocking out electronics.
Air and venting:
Inadequate venting can also cause incomplete combustion of gas ... since
the unit takes bigger incoming gas line, it is logical that unit will
also breathe in more air and blow out more combustion byproduct. Is the
vent sized correctly? Are there obstructions in the vent, such as
several bends or turns? Is there adequate incoming air supply?
Defective product:
Malfunctioning unit, bad sensors, defects, bad pc
board, there are a lot of reasons unrelated to code 11 that can be
causing problem.
But if you installed yourself, it can invalidate product warranty.
There was a guy who had similar problem, and sent unit back to Rheem, and they hooked it up and detected no problem and sent it back ... end of story ... guy never got it working and lost his money.
Warranty and explosions:
Rheem does not recommend installing tankless yourself because there are many potential problems, including voiding product warranty and/or blowing up house.
Gas appliances are dangerous. Inexperienced handyman should not do this installation without extensive reading about the myriad of mistakes other people made... that professionals tend to be aware of ... which is called experience.
Validate your installation:
to preserve warranty and avoid explosion:
Call Rheem to find qualified service tech located nearby who can look at installation while talking to Rheem on phone.
Your installation needs to be validated.
Since your unit requires yearly service, its good idea to find local service tech who will gladly take your money each year.
If area does not have qualified service tech, then do not install tankless, because the problems can be endless and without solution, and generally you can't fix the thing yourself. I answer questions on fixya. I see it.
Because tankless are generally not DIY, many problems are avoided by having professional installation since Rheem tells customers to contact the installer... a lot of help Rheem is ... but you are connecting a complex computer chip with sensors to 120 volt household wiring that has not been checked for polarity or correct voltage or line interference, and connecting to a gas line and burner with vent to outdoors. All these systems pose problems for tankless installations.
On top of inherent risk of gas appliance, which should only be installed and maintained by trained professionals.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
