Belkin (F5D5231-4) Router Logo
Sam2013 Posted on Jan 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a belkin 134. not sure what it does.,,?
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Jan 27, 2013
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1013665
Points
21773
1helpful
93 ranger a/c retrofitted to r-134 how many ozs of 134 sould I install
A good place to start is 80 percent of the original charge. IE: if your truck took 2.25 lbs of r-12, then multiply 2.25 x .8 = 1.8lbs x 16oz = 28.8 oz.
Janome 134 sewing machine needle moves while in winding bobbin
sometimes that happens the wheel could be stripped and not tighten all the way it will not hurt your machine just make sure it is not threaded
What type ac fluid used r-12 or r-134
Check the schrader valves where you charge the A/C system if it has threads on it like you can screw on the A/C manifold gauges then its R-12 if it has the type that couple on and no threads then its R-134 but make sure no one has screwed on some 134 fittings on them. Normally on the outside there it should tell you what type freon that vehicle should take you need to look around under the hood at the labels and see if you cant locate it.
Where is the low side ac conection on a 2001 altima located. I found one conection but not sure witch it is. when I conected the 134 refill can, the little gauge on top went to the red high pressure...
If you are getting a high reading then you have a problem with the system. Only other thing is make sure you have the valve turned off, The gauge and R-134 connected and then slowly turn the gauge handle. Sometime these will give you a high reading if it wasn't hooked up correct. The system was modified so the gauge will fit on the low pressure side. Good Luck.
1helpful
DOES THE 95 TAKE 134 FOR THE AIR THANKS
all 95's use r-134.
any older cars that have r-12 should be converted to r-134.
most auto parts stores sell the package to convert them.
1helpful
1999 gmc Jimmy only Blows hot air. Diverter actuator is moving and working. Even when compressor starts all pipes are hot. Check 134A and was low. When put in less than a can the compressor would cycle on...
When recharging the ac you need to recover the old refridgerent. That means you have to take out all the old 134 and replace with new 134. On the engine sticker under the hood should tell you how many pounds of 134 it takes. When put in the 134 make sure your ac is on high.
2answers
Where is the low pressure port A/C port on a 1997 Lincoln Mark VIII. Be more specific than the smaller port on the larger line as the smaller port on the larger line doesn't fit any of the refrigerant...
LOW PRESSURE PORT HAS A BLUE CAP ON IT.MAKE SURE YOU ARE USING REFRIGERANT R-134 BLUE CHARGE HOSE.R-12 CHARGING HOSE WILL NOT FIT R-134 SYSTEMS.SEE YOUR CAR HAS R-134 REFRIGERANT SYSTEM. THE EARLY 90S CARS HAVE R-12 REFRIGERANT SYSTEM.YOU NEED R-134 CHARGE HOSE SET.
2helpful
Need to know normal pressure for 134-a to recharge my refrigerator
Depending upon the way you charge it you could introduce air into the system. The lines need to be bleed before charging to make sure the refrigerant is in the charge lines and not air. Most folks that do not do this for a living make that mistake.
With air in a 134 system problems will abound. The only way to really charge a system is to use a vacuum pump to pull it down then charge to the correct lever in ounces as provided on the label of the refrigerant u purchase
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
