My other half touched my amp at a party and no sound has come out of it since.nothing was spilled on it but i was using it to its full capacity at the time.the front still lights up and shows everything works just no music
SOURCE: red light
Have you disconnected the wire from the speaker?? and the amp?? Maybe the wire is pinched as I suggested?? If not then yes I would sy the peaker could be bad or the amp output on that channelis fried.
SOURCE: Playstation 3 dont work half the time.
You and most all PS3 owners have or will experience this problem. Your Heat Transfer compound is dried up. This to me is a definite Manufacturer Defect. Contact Sony at 1800 345-7669 unless your outside North America. If you know how to get to the heat sinks, I suggest you go there and put some new high quality Heat Transfer compound between your processors and the heat sinks.
Tell anyone you know that if htye go to buy a PS3 or any Newer Video Game console, that they should buy the repair insurance. Go to www.playstation.com and find your country and set up a repair.
SOURCE: Reduced audio output from right channel
Try lightly tapping on chassis to see if you can get audio to cut on or off with vibration if you can most likely cause is bad solder connections. This unit is well known for poor solder connections especially around poweramp driver IC's IC701, IC501. Also Electrolytic Capacitors in unit have fluid in them and heat Evaporates the fluid causing them to not operate properly over time . Caps that usually go bad are around parts that run hot like Power amp drivers
Just a couple likely suspects.
Try unplugging overnight to give unit a Good Reset also double check all setup settings.
If you need service manual I may be able to get you one
[email protected]
SOURCE: front speaker channel cut off
always check the audio cables with another set before you do anything else.
SOURCE: Blinking Red Light - Nothing Works
Call Sony, give them serial number (rear of unit) provide descripton of problem and failure to operate after powering off and they will issue a case number and give you an address in Lubock TX to send the unit. Send the unit, with the case number showing on the shipping label, include a proof of purchase, description of problem, return address. Also if you like me, have CD's in the changer make sure you note that during the telephone call with Sony and again on the description of problem. Very fast phone call.
It sounds like you have a broken output filter inductor in the amplifier. You should be aware that the speaker outputs of the amp are biased at ~40v DC and can give a good shock if you touch the speaker wire while you're grounded (touching the body of the vehicle).
When you connected the speaker as you did, I would have expected the speaker to move in or out and remain there while the wire was connected to the housing of the amp. I'll assume that the amp was screwed down to the chassis of the vehicle. If it wasn't, you may have more than one problem.
