I changed the shock absorbers but it didn't make a difference. It also vibrates
See if the tub will spin freely by hand. Spin it both ways. It should coast silently to a stop. If you hear a dragging sound or it doesn't spin smoothly look for a sock between the inner and outer tubs. Start looking in the upper left side at about the 10:00 and 11:00 positions. That's where i usually find them.
If it seems to spin ok then see if the inner tub wobbles separately from the outer drum. Push up on inner basket from inside. The outer drum and inner tub should rise and fall as a solid piece. If you feel a separation the bearings need replaced or the spider assembly has broken. Only a complete teardown can tell which. Hope this helps.
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
SOURCE: AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
SOURCE: spining makes noise and machine vibrates a lot
All machines vibrate and make sound while spinning including front load. Dont worry, its perfectly fine
SOURCE: I have a whirlpool ultimate care 2 washing machine
here is one trick to do. put the timer on spin and pull out the timer knob. open the lid and use a screw driver to actuate the lid switch. then with your other hand hold the agitator until the tub gets to a high spin. once the unit is at a high spin then let go of the agitator. let the unit spin for another minute then lift up you screw driver. it should come to a gradual stop and not a sudden stop. let me konw if that works.
SOURCE: when spinning the drum seems like it hits side
You need to take the shock off one of the pins and check to see if it is hard to move it in and out... if it moves easily then it is bad. Also check to make sure that none of the loops that the pin goes through are broken.
My bet is that the spring is broken inside of the shock where you cannot see it. you will need to actually move it in ans out to check it.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
When
my washer did that, I found that the shocks that hold the tub were
bad...
Check out this tip I wrote about the noise and
vibration that front load washers can make..
Washer Problems
Washer
noise
when spinning
heatman101
When
bad...
Washer Problems
Washer
noise
when spinning
heatman101
