An E6 error code on a Belling induction hob typically indicates an issue with the power supply or the circuit board that controls the back two rings. Here are a few steps you can take to troubleshoot the issue:
Reset the hob: Try turning off the power to the hob for a few minutes and then turning it back on. This can sometimes reset the circuit board and clear the error code.
Check the power supply: Make sure the hob is receiving a stable and adequate power supply. Check the circuit breaker or fuse for the hob to ensure it is not tripped or blown.
Check the wiring: Inspect the wiring and connections for the back two rings to ensure they are not loose or damaged. Tighten any loose connections or replace any damaged wiring.
Contact a professional: If the issue persists, it may be a problem with the circuit board or control module. In this case, it's best to contact a professional technician or the manufacturer for assistance with repairs or replacement parts.
I hope this helps you resolve the issue with your Belling induction
Unfortunately, Induction hobs on domestic cookers have always been a problem. A single, one ring catering hob is $1,200 and is expected to last 2 years in an industrial environment.
There are two videos here, but I reckon you will need a service call.
E0 error - ensure pot or pan is placed correctly E1 error - the circuit has malfunctioned E2 error - the temperature sensor is opening circuit or short circuit E3 error - the voltage is higher (140 - 160V) for 3 seconds E4 error - the voltage is lower (80 - 100V) for 3 seconds E5 error - the cooktop surface temperature is too high E6 error - Internal electronic temperature is higher than normal for 3 seconds E7 error - Internal electronic temperature sensor is opening circuit or short circuit
