Televison & Video Logo
Anonymous Posted on Jan 27, 2013
This Westinghouse tv 1080pure will not turn on, all it shows is the orange light every time i plug it in. I've tried unplugging it and plugging it back in but it still dosent turn on
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1360
Points
Have you tried turning the tv on from the tv instead of the remote ??
  • Anonymous Jan 30, 2013
    Yeah
  • James Hill Jan 12, 2020
    When plug tv light by power button blinks yellow or orange
5 Related Answers
Anonymous
  • 132 Answers
  • Posted on Mar 29, 2009
SOURCE: JVC tV D series will not turn on when I hit power
Hi There,
Did you try turning it on from the actual TV power button?
Anonymous
  • 3130 Answers
  • Posted on Aug 07, 2006
SOURCE: TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
MARR
marcial nasi
  • 49 Answers
  • Posted on Sep 13, 2006
SOURCE: T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Anonymous
  • 934 Answers
  • Posted on Dec 07, 2007
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Anonymous
  • 1153 Answers
  • Posted on Jan 08, 2008
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
I have a Westinghouse VR-4625 TV that powers on, but fails to boot.
Try this....with the TV off put a hair dryer in the back lower fins of the TV and let it run on high for about 5 mins, shut the hair dryer off and see if the set comes on the way it should..If it does I'll tell you how to fix it, if it doesn't I've got some other ideas but want you to try this first
2answers
Westinghouse 55 inch tv red light stays on blue light comes on and turns back off I have replaced the power supply board already because it was on when it all went off no power at all
Hi i would need more info. what is the model number. its not always the power board it can be a processor fault. and thats the main av board. the processor is what turns on all the parts to start up.
4helpful
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
2answers
I have a westinghouse 42" lcd tv. Was working in the morning, ran some errands and when I went to turn it on, only the blue power light came on. No picture or sound. The only way to get the light to turn...
I had a similar problem with 2 other lcds. In one of them there were 3 capacitors that needed to be changed. In the other the main (biggest capactior) needed to be replaced. Someone may have already posted the solution for this tv with more details than I can provide.
5helpful
I have a Westinghouse TV , when turned on the Westinghouse symbol W comes up but no picture or sound and then it turns black. The light stays a solid orange. what can i do to fix my t.v
I just fixed the same model and with your symptom. What it appears to be is the main module is locking up just after the Logo goes away. All you can do is unplug and try again and all you will get is the logo for 5 seconds and then black screen, no sound and led stays lit. Cannot turn off or on. The power supply is actually working fine, it's the main module that has died. This module is no longer available, the part number was W470PROLX68. What i did to restore operation on this unit was to insert 3 volts into the plug going to the master inverter board and then plugged the tv AC cord in. The set showed the logo and then it started working. I removed the 3 volts and it has worked every time since then.
Here is what you should try to do: First take two AA batteries and solder them in series and attach two short wires so you can use it as a power source. Now you have a 3 volts power supply. Next Remove the stand first before removing the back cover. Looking at the back of the unit you will see the power supply and the main circuit boards in the middle (under metal shields) and two boards on each side. These are partially covered with a metal shield, the one on the left side is the master inverter, the one on the right is the slave inv. They both have a plug and wires going to them from the power supply, but the one to the master will have two extra wires. I believe the colors are purple and blue, and they are separated with an empty hole (unused part of the plug). The wire on the end is where you will hook up the positive lead of your battery pack. The negative lead simply goes to the metal shield. With these hooked up plug the tv into the ac and give it a couple seconds and hopfully you will see the tv come on. If it does then disconnect the battery pack and try it without it. good luck.
21helpful
7answers
My Westinghouse won't turn on, please help!
I had the same problem...turned out it wasnt the TV at all. It was actually the wall socket. Seems I had to many things plugged into one wall supply. (i.e. xbox 360, wii, audio reciever, dvd player, vcr, etc...) after switching some other items to a different socket my TV works GREAT!! I hope your problem is this simple!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
