Question about Integra Dtr-20.3 THX Select2 Plus AV Receiver
Integrea DTR-20.3 HDMI video output died from any input
This occurred when changing between stored TV shows on the DVR Connection had been working for over 15 months. Audio from any selected input still works FIOS DVR direct to TV works via HDMI cable, DVD direct to TV Work via HDMI cable Is there a "video mute" feature?
Posted by Chris Lewis on
2 Related Answers
Anonymous
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
Anonymous
SOURCE: the reciver dosnt get a signal from the hdmi
HAVING THE SAME PROBLEM. omg. maybe there is help. will get audio but no video from DPS dvd player and PS3. no onscreen menu either. changed hdmi cord. seems to be problem with reciever. DVD works fine when changing to component cables instead of the HDMI. sometimes plugging and unplugging the HDMI cable gets the PS3 working. Don't quite understand scrap605's suggestion. but that doesn't solve this prob.
Posted on Mar 07, 2010
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
Pretty good problem description.
Make sure the DVR/VCR2 digital input is assigned to the Cable box.
When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
Mar 31, 2010 | Audio Players & Recorders
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Have just purchased DVR-LX60D. Owning a DVD-696, am familiar with the setup of activating the HDMI output and the front panel of the DVR is showing that HDMI output is active. Fine so far. However, there...
sometimes with certain sets you have too on remote use the input for video 1 video 2 video 3
with hdmi certain tvs require one of the videos to be on to watch in high quality
May 28, 2008 | Pioneer Televison & Video
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Integra Dtr-20.3 THX Select2 Plus AV Receiver Logo
75 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
