Question about Kenwood Car Audio & Video
Kenwood kdc-200u looses all of the setup when power is turned off
After going thru the setup / turned off the demo mode. when turning off the key and then back on again it looses all of the setup and I have to start all over again. I even tried to reset but the same thing happens. why ?
Posted by Dennis Freshour on
  • Dennis Freshour Jan 29, 2013
    Kenwood demo mode / All fixed up. Thanks for all of the input
tim fitch
    New Friend:
Make sure your batt wire is hooked up correctly, there are two power wires one is constant and one is for the ignition, make sure the constant is hooked up correctly
Posted on Jan 27, 2013
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Cant turn off the demo mode
There is often confusion in the way the manual states how to achieve removing demo mode. Because this is listed in the "Menu System" section of the manual and assumes you read from page 1 of the manual that you will know to enter the menu in this section of the manual. Here is step by step instructions on removing demo mode on your unit. 1. Go to standby mode 2. Press and hold the menu button till the menu comes up 3. Press control knob towards AM or FM to scroll through menu till you locate "Demo On" 4. Press control knob straight in for approximately 3 seconds till it switches to "Demo Off" 5. Hit menu button again to exit menu
Posted on May 07, 2007
simplemitch
Mitch
  • 752 Answers
SOURCE: How to turn off this blasted DEMO mode on MP235
Once in standby you have to press and hold the button to get into the menu. Once in the menu, you use the joystick control on the right to navigate to "Demo" and toggle it to "off" (can't remember off the top of my head... you either have to press the joystick in and hold it to toggle or just move it up/down...). Once done, just press Source to exit.
Posted on Sep 11, 2007
Anonymous
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
Anonymous
SOURCE: Problem with Demo mode turning off Kenwood KDC-WF431
Hello. Have the same problem. Have just downloaded the Manual in German. It says In Standby Mode use the small joystick up to FM or AM till it says DEMO OFF and then press the small joystick for 2 Seconds. Hope this helps.
Paul
Posted on Aug 18, 2010
Anonymous
SOURCE: cant turnoff the demo mode in my Kenwood KDC-MP142
get in to "menu" (hold magnifying glass), scroll to "demo mode" (am or fm button), push volume knob in and hold for about three seconds. Should work, that's how I did it.
Posted on Sep 02, 2010
No radio rception,player is in demo mode
1. Press and hold the SETUP button for at least 3
seconds.
2 Press the f UP or g DN button to select the
"DEMO" mode.
3 Press the BAND button to turn on or off the DEMO
mode.
Each press toggles between "DEMO ON" and "DEMO
OFF."
If no buttons are pressed 30 seconds after the DEMO
mode is turned ON. The DEMO mode then begins.
NOTE
The initial setting at the factory is "DEMO ON."
4 Press the SETUP button again to return to normal
operation
Nov 18, 2013 | Alpine CDM-7892R CD Player
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
Aug 28, 2012 | Sony XPLOD CDX-GT200 CD Player
It keeps on showing demo and we dont know how to get it started again
Depends on the model but here is a video for one model: http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportHowToGuideDetail?storeId=15001&idval=UCM_STG_CNT_037074&catname=Microwave+Ovens&title=How%20to%20deactivate%20the%20Demo%20Mode
In most Panasonic models, the DEMO mode is turned on or off with "Fn + 5" key combination. So if you are stuck in Demo mode, press Fn followed by 5 it will bring you out of it. Other times, it could be Fn + 0 and then Press 1 to turn on the demo mode and 2 to turn it off.
If there is no Fn key on the touch pad then it could be something like tapping the ON or OFF key four times
Jul 17, 2011 | Panasonic Microwave Ovens
I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
When in Demo Mode, the console will go through a repeating lighting pattern. This
mode will only become active when the treadmill is plugged in, the main on/off switch
is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By
default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be
turned off at any time.
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
Look in the Calories window. When Demo Mode is active, the letter 'd' will
appear.
Press the SPEED DOWN button to toggle the mode on and off.
Once the mode is set as desired, remove the safety key.
May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
I can't turn off the demo mode on my sony bravia tv
Press Menu on tv remote, go to Settings and select Factory Reset and press enter button on remote, tv will reset to factory default settings and turn Off and On again itself, now select HOME mode instead of Shop mode to avoid demo mode and go by initial setup screen instructions.
Above are generic info about Sony bravia tv, let me know model number of your tv if you do not see factory reset option in settings menu.
Thanks.
Nov 08, 2010 | Sony Televison & Video
STR-DE845 Stuck in Demo mode, tried the power and ...
To get the STR-DE845 ( or STR-DE945 ) out of DEMO MODE - Turn unit on and HOLD POWER BUTTON FOR A FEW SECONDS ...Turn unit off and when you turn it on again it should be reset ...It worked for me.
( Note : You may need to do this procedure before it goes into its actual demonstration of features ... Press and hold the power button immediately when it initially starts scrolling it's DEMONSTRATION MODE message . )
May 12, 2010 | Audio Players & Recorders
Loses channels when shut off. must auto program
Your may be in shop mode, I'm not sure if Vizio's have a service menu. Go to setup and go through the install process again, watch for a demo or shop mode setting. If there isn't a setting then you need a new mainboard
Mar 22, 2009 | Vizio VW32L 32 in. LCD HDTV
How can I get it to display the clock only when off?
Download an owner's manual here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXS2010&LOC=3 To turn off the demo mode, first make sure the unit is turned off and your key is on. Press and hold the SEL button until you enter the setup mode. Press and release the SEL button until you see "DEMO". Press the volume up/down buttons to turn DEMO off. Press and hold the SEL button to exit the setup menu.
Jul 31, 2007 | Sony CDX-S2010 CD Player
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Car Audio & Video Logo
308 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
