Keyboard is psycho, typing different letters each time a key is hit in different programs.
Keyboard is typing wrong letters in some programs and will not type an "h" at all. Each key will type many different letters when touched, but if held down for repeat it repeats the same letter. The non-letter keys type correctly. The number keys will type different numbers. I have had this keyboard for a long time and never had this problem before. It is the Microsoft Wireless Intellitype Keyboard.
Posted by Janice Duncan on
Ric Shanahan
    New Friend:
  • 61 Answers
First of all make sure the batteries are fresh. Download the latest driver. Make sure the path to the wireless dongle is OK, not blocked. Re-seat the dongle. If all else fails try a wired keyboard. Consider getting a new keyboard.
Posted on Jan 26, 2013
Testimonial: "I do go through a lot of batteries with it, so that is a possibility. The dongle is okay and I can try a wired keyboard if all else fails, but I went wireless because the cords were too short, but I do have several extensions now, so that is not a problem. Thank you these are great suggestions. "
Anthony Thomas
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Replace it
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: keyboard probs advent 9115 laptop
Sounds like your num lock has been toggled on by mistake. Look for a key that says NmLK. It will be in the same color blue. That key may also be the scroll lock key(ScrLk) that should solve your problem.
Thanks
Todd
www.LaptopGuy.com
Posted on Apr 23, 2008
Anonymous
  • 16 Answers
SOURCE: What Fn Key enables the keyboard to type letters instead of #s
use fn key plus numlk key
Posted on Jan 13, 2009
Michael James
  • 61 Answers
SOURCE: my laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
Posted on Mar 18, 2009
Anonymous
  • 12 Answers
SOURCE: keyboard is not working properly-some of the letter keys also have numbers and when I type in a letter the number is coming up
look in bios, for numlock boot
thats why the number function works instead of the letter,
just got 16 odd at work and its my job to put xp pro on, with out a cd drive, if u need xp pro or another os hit me bk
Posted on May 18, 2009
virtualhost
virtualhost
  • 2185 Answers
SOURCE: when typing along the keyboard qwertyuiop, the
This means that NUM LOCK is set to on. All you have to do is to press the Fn key and then locate the NumLock key and press it. The num lock is usually also highlighted with the same color as the Fn key.
Please comment back if you still have issues. I will be glad to assist you further.
Posted on Aug 06, 2009
While typing, the keys change to different letters
Is your shift key stuck in the down position? Try pressing it a few times to release the key.
Jul 08, 2017 | Dell Inspiron 1545 Notebook
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
I have a problem regarding my lg x110 notebook. some keys are not working properly like the letter g on the keyboard, when i hit the letter g it appears letter c on the monitor same as letter t and z and...
Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
Check if your number lock key is on. If so, depress the key to disengage it.
Run a character key test by using the Microsoft Keyboard Diagnostics (MSKEY) program. While in the MSKEY program, hit several keys to make certain that they are the same keys that are identified in the MSKEY window. To start MSKEY in Windows Vista, select "All Programs>>Accessories>>Run" from the Start menu. Type "mskey" in the box and depress the "OK" button. Start MSKEY In Windows XP by clicking on "Run" from the Start menu. Type "mskey" in the Open box, then hit "OK." Depress either "PS/2" or "USB" to apply it to your type of keyboard hookup. MSKEY software is only available with Microsoft IntelliType version 1.1 or later.
Remember to clean your keyboard regularly to keep it free of dust and debris.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty!
May 08, 2011 | LG Computers & Internet
Laptop Keybord is not working properly. If we click on one letter it is showing another letter.
Download and run Ccleaner here:
Run cleaner and registry cleaner. then:
Plug your keyboard into another computer. If the keyboard works, then the port on your original computer may not be working.
5
Tips & Warnings
Clean your keyboard regularly to keep it free of dust and debris.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty.
Good luck. If this helps please consider giving me a good review.
Thank you and good luck
Oct 19, 2010 | Acer Computers & Internet
Can't type some letters
sounds like either there is something stuck under keys ie (kids toys, food scraps, stuff) or keyboard is bad
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Logitech 9675020403 Keyboard
A key (which one?) changes the letters all keys type
You're hitting SHIFT and CTRL -- which changes the keyboard input method, i.e., for French keyboard, or for DVORAK keyboard, or for Scandinavian keyboard.
Access CONTROL PANEL, and use REGIONAL settings to "uninstall" all keyboard-layouts that you _never_ use.
Jul 01, 2009 | Microsoft Natural Ergonomic 4000
Acer travelmate 4050 keyboard prints wrong keys
Hold the Fn key then hit F11. This toggles the numeric nubers to letters and vice versa.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 20, 2009 | Acer NSK8458AN Keyboard
Keyboard is messed up
Try looking here to see if any of the keys are set wrong.
Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Dec 14, 2008 | Saitek Eclipse (PZ30AUR) Keyboard
WHEN TYPING THE WRONG LETTERS PRINT
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Jan 25, 2008 | IBM Wheelwriter 30 Typewriter
Computers & Internet Logo
435 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
