Question about Saitek Video Game Consoles & Games
Connect Saitek R220 (DHPW6) to xbox 360 - Saitek Video Game Consoles & Games
1 Related Answer
Anonymous
  • 60 Answers
SOURCE: My Saitek PX3200 2-in-1 Rumble Pad (Xbox 360) has stopped working
Try replacing the rumble pad.. Could be faulty.
Posted on May 09, 2010
1helpful
XBox 360, joysticke working fine until a few minutes ago. Now it pulls aircraft to left into dive, no throttle, no control, nosedives into deck Switch on side is in correct position & connection is...
Try blowing it down with a hair dryer or shaking it out ad gently use a cloth cause something might be sticking to it or inside. (Trust me because the same thing happens with my computer mouse and keyboard). O and it also might be a technology error so maybe reset the device.
Can I use this on the xbox 360 or the playstation3?
http://www.amazon.com/Saitek-PS41-Aviator-Joystick-Console/dp/B001EYU1W8
Installed all the software so that the xbox 360 controller would connect to my pc. the controller turns on but it doesn' connect to the pc. my computer recognizes the controller and says that it's ready to...
If by "Doesn't connect to the PC" you mean won't play games, it's because only new games can use the 360 controllers as it doesn't use the DirectX input, but uses XInput instead.
There are supposed to be solutions, sometimes through updates for the games (an example in reverse was an update for GTAIV, which allowed the use of the older DirectX joypads.)  I've also seen software (switchblade) that allows various pads to work with RPGs.  Not too sure if that would be suitable for you though.
Since I have both types of controller (both X360 and a Saitek Pad) I've never had to resort to any other fixes.
JBV^_^
How can i connect my controller? it shows up on my pc but i cant use it.
install the driver of the controller and remember check if the Game that you are playin supports the controller that youre usinG :)
*Example Prince of Persia - Elika to the Prince Game requires XBOX 360 for PC controller
2helpful
My xbox 360 controller will not connect to my xbox but it will connect to my friends xbox
See if any xbox controllers will connect to your 360. If you can't get any to connect to your xbox 360 then that means you have a bad controller board. If you can get other controllers to connect then that means you need to configure your xbox to accept that xbox controller.
5helpful
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
My Saitek game pad will not work with Call of
the game doesn't supports any controller except xbox 360 controller
Saitek 380 does not work properly with xp sp3
a lot of games need the xbox 360 controller i have encontered the same problem and i just use a xbox 360 controller
Video Game Consoles & Games Logo
Top Saitek Video Game Consoles & Games Experts
Ekse
 TE5LA
TE5LA
ADMIN Canada
ADMIN Canada
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
