Copier feature of HP Officejet Pro K550 Series produces a print page that appears to be a combination of color and the page contains this image on the entire paper surface
The copier function has always performed well. I used a thick colored paper stock and my image to be copied is black and white. One copy was produced correctly, but then the image became a solid (8x10) mass of vertical streaky lines. Lines appeared to be a combination of black and purple. All copies made after the first one resulted in this problem. Even when the supply tray was filled with white stock this bizarre result continued. It is only the copier feature, Print sent to the printer from my pc prints fine.
Posted by lynn399 on
Anthony Thomas
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Your printer ink heads may need to be reset/relined.
Posted on Jan 26, 2013
2 Related Answers
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Posted on Nov 11, 2008
Anonymous
  • 97 Answers
SOURCE: All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Posted on Jan 23, 2009
Hi, i have an HP Officejet pro k550 series printer and i dont know how to set the wireless setting, eg. IP configuration
If you printer has the optional Jetdirect print server istalled and you have a wireless router, then to configure this printer for your wireless network, please click on this link and follow my instructions.
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Jul 04, 2011 | HP OfficeJet Pro k550 Printer
Officejet Pro K550 text prints grey instead of black
go to the printer control panel, right click your printer and open preference or may be properties on your end, Click the Color tab, and change the color option to black or color. hope this helps. feel free to rate how helpful it is.
Oct 07, 2010 | HP OfficeJet Pro k550 Printer
Cartridge new but printer not printing
Check the Print heads and clean them if neccassary.
May 29, 2010 | HP OfficeJet Pro k550 Printer
My HPOfficejet Pro K550 will not print checks correctly
Hi crys smith -
for future refs: if the paper type and size (in this case checks) is set up correctly in the software that you are using to create the checks, perhaps it would help to check the printer settings. this link at hp support might help you then:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00494598&dlc=en&product=501369
it includes checking and changing print settings and stopping a print job. (-and no one wants to waste checks!) -JW50
Aug 26, 2008 | HP OfficeJet Pro k550 Printer
Only prints one page
You could try using these drivers on the Hp.com. These drivers were from March of 2007.
This was listed at Officejet K550. They didn't have a Pro Printer listed. If there are any letters after the model number you should go to that page instead.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=501369&lang=en
Jun 14, 2008 | HP OfficeJet Pro k550 Printer
HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
Jan 06, 2008 | HP OfficeJet Pro k550 Printer
79 people viewed this question
Ekse
Marvin
Marvin
