Is my Neptune suppose to hold water?
SOURCE: sound like water still in washer
its water in the tub ring only thats to balance the load while in use..no water in bottom of tub,,you will here the sound of water in the ring when door is open and tub ismove,,but thats all..you will never see water,,if you see water there a problem..onthejob
SOURCE: Maytag Neptune Washer Wont Spin Water Off
I have a maytag too and this is a easy one and you will be so relieved when you get this done!! and your wife is going to love you toooo !! just unplug the machine 1ST then go to the back uncscrew the back panel right at the bottom of the machine is a pump its got a hose from the tub into the pump and then it leaves the pump into another hose to which leaves your home.... you can unbolt this.. take the hoses loose on both ends . Next take that the drain and hoses and wash them out / I found only a piece of paper clip around the little propeller of course i had to replace the pump but really its not that expensive. I got mine on line ebay.... like $ 20.00 but if you are lucky then you can clean that good. I even went as far as taking it apart a total of 10 minutes tops, just to find out what could be letting this not spin.... maybe yours wont be so tramatic but if it is be relieved when you know it was this simple to fix !!! good luck to you and yours.
SOURCE: Maytag Neptune Washer - bleach and softner do not
clean water inlet filter,then check to see if the outlet tubes from the dispenser to the tub are blocked or partially blocked with detergent.
I use liquid detergent... no problem.
Cheers
SOURCE: When the washer gets to the spin dry cycle, the
Thanks for choosing FixYa and welcome.
Testimonial: "Just having someone offer suggestions or solutions is very helpful. It helps to know I am not alone in trying to resolve a problem. Love this site!"
SOURCE: Hotpoint wd440 washer/dryer. 1st problem was it
Make sure that the outlet of the pipe is at least as high above the floor as the top of the machine. If it is lower than the level of the water, it will just drain - there is no shut-off valve to stop it from doing this. Please rate this answer.
