SOURCE: ricoh mp c3000 display error
make sure there is no paper at the back of the tray.also make sure the tray lift motor is working.the last thing to check is that there is nothig broking of the back of your paper tray..
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
SOURCE: Ricoh Aficio MP 161 giving me an error code of
One of the following controllers is
installed to the basic model:
* The controller of the MFP
model
copier/facsimile model
printer/scanner/copier
model
OR
The controller of the optional
printer/scanner is installed to one of
the following models:
* The MFP model
* The copier/facsimile model
* The printer/scanner/copier
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
SOURCE: eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
