Cars & Trucks Logo
Anonymous Posted on Jan 29, 2009
1989 350 runs rough for a while after ineling
1989 suburban 350 1/2 ton Engine starts fine and runs great but if it sits and idles for a time it seems to load up on fuel and runs rough even back fires for a time ,but when it finally gets up to speed ,3to5 miles on Interstate it will smooth out and run fine.
  • 3 more comments
  • Anonymous Jan 30, 2009
    The converter and entire exaust system is new
  • Anonymous Feb 13, 2009
    Thanks but I have found the problem ,it seems that the vacume line from the intake to the breather had been lost when doing service .
    Thanks to all your help.
    Ferd
  • Anonymous Mar 17, 2014
    1989 gmc 350 engine , not getting fire from coil to distrubtor
  • Anonymous Mar 19, 2014
    The engine runs rough and almost dies at all speeds but at times it runs fine
  • Anonymous Mar 31, 2014
    Ideals smooth, but runs rough and bogs down
Anonymous
Level 3:
Genius:
  • Master 2,920 Answers
  • Posted on Jan 29, 2009
Anonymous
Master
Level 3:
Genius:
Answers
2920
Questions
0
Helped
934888
Points
7574
Have the converter checked it may be partially clogged
Runs rough idle
your idle valve may be dirty or needs replacing would check this as it controls idle. sits on the intake with wires coming out of it.
2answers
Rough Idle when starting when motor is warmed up
My brother has a Ford F150 that does this the problem turned out to be a bad mass air sensor (little black box with plug in on it located next to the air box on the air intake pipe
1991 Cadillac Sedan Deville idling rough
True of many cars. Happened to me too many times, fourin
or domestic.
1helpful
1988 chevy suburban 1/2 ton auto trans; 4 wd; dies after putting into drive
Could be a dirty throttle body or faulty idle air control valve.
Is the check engine light on ?
Idle good when cold, hotter it gets the worst it idles especially when sitting at stop lights
simple test for a vacuum brake booster
star and run the engine at idle without applying the foot brake
if it gets worse when the foot brake is applied , it is a vacuum leak in the booster ( replace the booster )
otherwise check for failed vacuum hoses including under dash control lines , vacuum leak at the manifold or EGR unit
I have a 2001 chevy suburban 5.3. when i bought it i just oils change,new battery,spark plugs and wires still runs rough as p0300 what is reason?
This is a random misfire of all the engine cylinders, the causes are many and each must be diagnosed to fix the problem. If you click this LINK you will go to the best info I know of for diagnosing the problem.
Hesitation while exceleration
Have these things checked for #1:
Spark plug
plug wire
#1 fuel injector
and the throttle position sensor, also have a fuel pressure test done, especially for the hesitation.
2answers
Chevy 350 express van 2000 runs great idles rough
If it does not do it in park or neutral, it could be a number of things. One being a sticking Torque Converter Clutch solenoid (TCC). It could be that it needs a simple tune-up. How often does this problem happen?
3helpful
2answers
2002 Kia Rio runs rough when idling
well spend some change and have a simple tune-up.  Plugs and filters and readjust the idle.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
