Question about Konica Minolta Bizhub C220 Color Copier
How to clean transferbelt in bizhub c220
Transfer belt is dirty need to clean the same, any solution for that
Posted by sushil singh on
Adorjani Laszlo
  • Konica Minolta Master
  • 1,316 Answers
Remove the transfer belt unit,remove the upper cover and used a vacum cleaner,cleaning under transfer belt cleaning belt section.
Posted on Jan 29, 2013
1 Related Answer
Anonymous
  • 145 Answers
SOURCE: Need to reset the fuser and transfer belt alarm in
can not be reset .it has to be reset manualy by a technician or replacing the units...
Posted on Mar 01, 2010
KONICA MINOLTA BIZHUB C253 DISCOLORATION
please attach pictures ....i have to see for better understundaning and solving your problem.
Aug 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
8650 machine error 21
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
Hope fully not the last two expensive.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 04, 2014 | Konica Minolta bizhub C250 All-In-One...
Error Code C2152
Transfer belt code was it replaced properly?
Apr 17, 2014 | Konica Minolta Full Set For Bizhub C220...
How can solve error p 5 idc sensor in konica minolta bizhub c450
P5 front IDC sensor failure.Wipe clean the surface of the transfer belt if it is dirty with a soft cloth or change the transfer belt unit is damaged.Reinstall or reconnect IDC sensor shutter or connector for every color unit and clean the sensors when vacuum cleaner after remove the all imaging units and the transfer belt unit.
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 error of c250
4 Change PRCB.
WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
Unit is in the right side cover. New one should have instructions with it, but I think you unlock a handle and swap, then lock handle again.
Apr 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How to solve error SC471 on my Ricoh alficio cl7000
This is a transferbelt home position error.
Book says:
1. Turn the main switch off and on.
2. Reset the transfer belt unit.
3. Clean or replace the transfer belt
sensor.
4. Replace the transfer belt contact
motor.
5. Check the contact and release
mechanism of the transfer belt unit.
My guess is cleaning will solve it.
open the front door and sing don the green lever
locate the 2 screws at the top and bottom of the unit and remove them.
remove the cleaning unit 1 screw and a thmb lever slide the unit out (its on rails) wipevacum and/or blow clean the unit and re assemble
also clean the connector that it plugs to in the back of the machine
(q-tip)
if it still appears belt or unit will need to be replaced
Apr 04, 2010 | Ricoh Aficio CL7000 Laser Printer
Replacing a transfer belt on a Konica BizHub C500. How do you replace it? Or which side of the transferbelt unit do you remove?
if i remember right, open right door, remove 2 tbu lock scews, open left cover, remove waste box and then remove tbu
Dec 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub C220 Color Copier Logo
540 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
