My door switch went bad so got one. then to my dismay i couldn't get it going but finally went back to site it said that a new harness is needed along with new striker. got it. man there is quite a few wires to replace and plug in's and splicing . and absolutely no color coding. any help would be greatly appreciated.. Momma wanting to wash them clothes.
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
SOURCE: No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
SOURCE: frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
SOURCE: Affinity Front load washer will not spin out clothes
I replaced the lock assembly. Took about 5 minutes and $70.00 part. It is working perfectly. I also cleaned the filter while I was at it.
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Instructions
<:section abp="1260">
Found this on the web . Hope this helps
