When I try to open anything having to do with Java Runtime Environment (JRE), command prompt opens and tells me, "javaw is not recognized as an internal or external command, operable program, or batch file." This is a problem due to me playing Minecraft and it runs on java, so I can not do a lot of things I would need to with it.
You must be logged in as an
administrator. If prompted for your administrator password after a
command, enter it and then press the Return or Enter key.
Open Terminal, located in the Utilities folder.
Enter this command, then press the Return or Enter key:
sudo mkdir -p /Library/Internet\ Plug-Ins/disabled
sudo mv /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin /Library/Internet\ Plug-Ins/disabled
sudo ln -sf /System/Library/Java/Support/Deploy.bundle/Contents/Resources/JavaPlugin2_NPAPI.plugin /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin
To re-enable Java SE 6 Web Start, enter this command, then press the Return or Enter key:
sudo ln -sf /System/Library/Frameworks/JavaVM.framework/Commands/javaws /usr/bin/javaws
Additional Information
The following steps will undo the above commands and restore Java 7.
Disable Java SE 6 Web Start opening:
Important: Mention of third-party
websites and products is for informational purposes only and constitutes
neither an endorsement nor a recommendation. Apple assumes no
responsibility with regard to the selection, performance or use of
information or products found at third-party websites. Apple provides
this only as a convenience to our users. Apple has not tested the
information found on these sites and makes no representations regarding
its accuracy or reliability. There are risks inherent in the use of any
information or products found on the Internet, and Apple assumes no
responsibility in this regard. Please understand that a third-party site
is independent from Apple and that Apple has no control over the
content on that website. Please contact the vendor for additional information.
Please try Re-installing Java Runtime Environment (JRE) in your system. Please Uninstall you JRE if it is installed already and reinstall. Also Unblock Frostwire from Windows Firewall. Please find below the steps to unblock frostwire:
Click "Start."
Type Windows Firewall and click on the
"Windows Firewall" in the search result.
Click on the "Allow a program" option
on the left-side of the Windows Firewall window.
Click the "Change
Settings" button.
Click the "Allow another program" button.
Select
"FrostWire" from the list of programs.
Click "Add" to unblock FrostWire
from the Windows Firewall.
If these two steps does not work, uninstall and re-install frostwire!
1.Open Default Programs by clicking the Start button, and then clicking Default Programs. 2.On choose the programs that windows uses by default, Select “Associate a file type or protocol with a program > Click on the extension (.jar) to view the program that opens it by default. 3. Click change the program and select the default program JAVA virtual machine launcher 4.Click close. Change-which-programs-Windows-uses-by-default http://windows.microsoft.com/en-US/windows-vista/Change-which-programs-Windows-uses-by-default Now check if the issue is resolved If the issue persists, you may want to uninstall and reinstall JAVA. How do I uninstall Java on my Windows computer? http://www.java.com/en/download/help/uninstall_java.xml How do I manually download and install Java for my Windows computer? http://java.com/en/download/help/windows_manual_download.xml If the issue still persists, you may want to check with MP3 rocket for any known issues http://www.mp3rocket.com/support/
Open Internet Explorer. Press [Alt] + [T] + [O] Choose the Advanced tab from the menu. Click on the [Reset] button below the Reset Internet Explorer Settings b section. Close Internet Explorer. Remove all versions of JRE (Java Runtime Environment). Install JRE 1.4.2_08 Open Internet Explorer and open the Yahoo mail page. Hopefully you should now be able to compose new mails and view the existing emails.
As i understand you receive an error when you run the installed program.
Please uninstall the complete downloaded software and reboot the PC. Then download the latest Java JRE (Java Runtime Environment (JRE) 6 Update 7) to run all Java programs from the link given below, http://java.sun.com/javase/downloads/index.jsp
Once you have installed the Java JRE, again install the program and test if it works.
