As Seen On TV Living Pure Pro Series 4-in-1 Heater Logo
Vickie Henderson Posted on Jan 25, 2013
On the 8200 Pure Living heater there is a small black object that was on the floor beside the heater and came apart. I need to replace this because the heater no longer will start
Kate
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 23, 2013
Kate
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
2283
Points
7
Contact seasonaire.com for replacement
they took over Living Pure
Mu 8200 living pure heater the power light is red and it says 75 degree but not heat what do I do
If your Mu 8200 Living Pure heater is displaying a red power light and the desired temperature but is not producing heat, it could be due to a malfunction in the heating element or thermostat. Here are a few things you can try to troubleshoot the problem:
  1. Make sure the heater is properly plugged in and that the outlet is functioning properly.
  2. Check the heater's control panel for any error messages or codes that may indicate a specific problem.
  3. Check the heating element for any damage or wear. If the heating element is damaged or worn, it may need to be replaced.
  4. Check the thermostat to make sure it is functioning properly. The thermostat controls the heating element and can cause the heater to shut off if it is not working correctly.
  5. Check the power cord and outlet for any damage or loose connections. Make sure the cord is securely plugged into the outlet and that the outlet is functioning properly.
How do I replace my Owners Manual for Living Pure 8200 series
go to their website, you should be able to download the manual then print it out.
Unit mailed for repairs....now seems to be lost, where do I go from here
Ya ever get it back??my switch went out on mine how do ya get it fixed?? It didn't last 1 winter o paid 350+ tax 4 this pos
want my money back NOW
We WE NEED CLASS ACTION LAY SUIT AGAINST THIS LIVING PURE HEATER COMPANY!!!!!
2answers
Reset switch broken
go to www.repairclinic.com and get the part and replace it.
God bless you
2helpful
2answers
I need a replacement power switch for model 9000w living pure 4-in-1 unit.
Remove the filter in the back. Unplug the four wires that went to switch. (2 black and 2 white) Cut metal ends off. Strip ends with wire strippers. Connect the white to the white and black to the black with wire nuts. Wrap with electrical tape. You've just bypassed the power switch. Now have a cocktail! You're done.
2helpful
Living pure pro series 9000 4-in-1 unit. I need a power switch replacement.
Living Pure was taken over by a company called Seasonaire. They take care of the Living Pure units and will replace it. I had the same issue with mine. I am awaiting them to ship out a new unit. It is under warranty.
3helpful
2answers
Living pure 4 in 1 broken switch
you can take out filter and inside unplug the 4 wires and directly connect black to black and white to white with electrical tape...make sure you tape it good-reassemble
1helpful
My living pure heater wont heat up after a breaker tripped
contact Seasonaire to replace your unit. They now take care of the warranties for Living Pure
Top As Seen On TV Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an As Seen On TV Televison and Video Expert? Answer questions, earn points and help others
