Question about Life Fitness Exercise & Fitness
Life fitness 95t speeds up in cool down - Life Fitness Exercise & Fitness
Posted by beach bum on
Sportsmith LLC
  • Life Fitness Master
  • 918 Answers
This sounds like a motor control board issue. In my experience I have seen it either speed up when it is supposed to slow down or you will get a pulsating or lunging type action in the running belt. There are companies available that can test and repair said board for a fraction of the price. You might check with Carolina Technical Services LifeFitness motor controller repair
Posted on Apr 23, 2014
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: I bought a used Life Fitness 95T from a fitness
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_11_41_39_am.gifThen tight the flexible cords from keypanel vs display board( clean the keypane with spray from contact cleaner. then tight the connector from display board vs main motor controller. Remember the main motor controller has aprox 90% of functions of any treadmills. See the block diagram that I did for people like you, And now you will get powerful strong resultant what is wrong. sincerely. Good luck.
finally 2 options: 1) display faulty 2) Main motor controller of course after you did the first step.
Posted on Nov 30, 2011
Replacing the belt
I am not sure of the make and model you are needing assistance with, but the following link will take you to a video that shows this procedure and should give you a good idea of how to do this on your machine. Life Fitness Treadmill Belt and Deck Replacement Video 95T
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Dec 02, 2015 | Exercise & Fitness
Why does it show motor comon error?
Electronic card malfunction. You need to change the mosfet material on it.
Apr 23, 2015 | Life Fitness T5-0 Treadmill Fitness...
Error fet
haga un RESET de la maquina . Recomiendo que Corra el Software calibration for facil diagnostico y reparacion que viene con la maquina. lea su manual de instruciones. or bajelo de
www.fitness.manualsonline.com
Dios le bendiga.
Jun 19, 2013 | Life Fitness T5-0 Treadmill Fitness...
The term immobilize is on the display panel and I want to start it up. How do I get it going again?
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill Fitness...
Heart rate Monitor not working on Life Fitness 95Ti Life Pulse
I would suggest removing your heart rate grips and inspecting the contact leads for rust or any other corrosion. This is very commonly an issue and can be resolved by either cleaning the contacts or simply replacing the parts. Using the following link, and your serial number, you should be able to find the contact grips if you end up needing them.
Repair Parts for LifeFitness 95T 95Ti 95Te Treadmills Midline SPORTSMITH...
Feb 18, 2013 | Life Fitness 95Ti Treadmill 95 Ti
Life fitness 95t speeds up after confirming slower speed in cool down mode, and also pauses after touching increase button on screen. both issues are dangerous
book an engineer, sound like motor controller, loose belt could also be a issue, needs a safety check where are you based ?
Jan 27, 2013 | Life Fitness Exercise & Fitness
95T Unit Immobilized by Manager
Press the speed arrow down 3 times, then the stop 3 times
Oct 08, 2012 | Exercise & Fitness
Exercise & Fitness Logo
77 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
