Question about Lenovo G550 PC Notebook
My Lenovo G550 is not having proper battery back up even with the new battery....what to do....?Back up is only for 4 minutes....(even with new battery)
Posted by Arvind Pandey on
max carson
  • Lenovo Master
  • 7,627 Answers
Assuming your battery is the proper spec, some inexpensive aftermarket batteries don't work well with laptops, Take a look at this forum : http://forums.lenovo.com/t5/Lenovo-3000-and-Essential/G550-Battery-Won-t-Charge/td-p/324357 AND this: http://forums.lenovo.com/t5/Lenovo-3000-and-Essential/G550-Battery-problems/td-p/654103
Posted on Jan 26, 2013
5 Related Answers
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: i buy a lenovo g550 laptop in 10 jan 2010,it
Hi Faiz,
It the battery is malfunctioning then you need to check if your machine is still in warranty and call the tech support hotline of Lenovo and ask for a replacement free of charge. However, Lenovo ships a replace to US, Austalia and New Zeland Address only. If your laptop is purchase from other country then you need to get intouch with the seller of your laptop
Lenovo Hotline: 1877-453-6686 or 1877-4LENOVO select Option 2
Thanks for using Fixya.
Posted on Feb 06, 2011
Anonymous
  • 274 Answers
SOURCE: how to install xp in lenovo g550, its cant able
fist go bios & give boot from cd RAM save it exit from there insert XP CD it will ask you press any key ,just pess it then it will start coping fails & drivers after that XP will install ok
Posted on Mar 08, 2010
Lastoni Wibowo
  • 2246 Answers
SOURCE: Describe your HOW CAN I REMOVE LENOVO G550 BIOS
go to biaos setting and disable password
Posted on Jan 08, 2011
SOURCE: i have a lenovo g550.
Hi blue_eyes_ca,
Do you mean that your system is not able to turn on after sleepmode and you need to push power button in order for it to turn on again?
If this is the case, you're system is actually not shutting down. The system is just having hard time turning on the system after sleep mode and this is because of the hard disk rotation being stopped.
You need to go to the Energy/Power management to change this setting to never.
Here's how:
1. Go to Start, select All Programs
2. Look for Lenovo Folder and expand the folder
3. Then select Enery/Power Management
4. The Energy/Power Management tool will open
5. Click on the mechanical icon and the settings will pop-up
6. Go to the system tab and change settings for "Stop Harddisk rotation" to Never
7. Save and Exit
Kindly observe the computer and see if it works. If my solution is not able to resolve your issue, please call Lenovo Warranty Support at 1877-453-6686 or 1877-737-1083 for OOW system.
Thank you for using Fixya,
avf110686
Posted on Apr 16, 2011
Testimonial: "my laptop had a battery problem, but before that, this was the way i fix it! Thx:*"
brian soufane
  • 693 Answers
SOURCE: my lenovo g550 keeps on
sounds like it's overheating and getting a memory error. try to clean out the case. run with the case open to see if if that helps. blow out the dust on the CPU heat sink
Posted on Aug 10, 2011
Battery does not last even 20 minutes
Simple, replace your battery.
Search online for Lenovo G550 replacement battery. They range in price from about $25 and up depending on brand and quality. The cheaper ones typically are Chinese import knock-offs, which can do fine, but may have reliability issues. I've had several and for the most part they work ok. For the price, its not likely buying the highest priced will necessarily make it any better in the long run. Just make sure the source you buy from (ebay, amazon, craigslist) are reputable and offer a replacement warranty.
Aug 26, 2012 | Lenovo G550 PC Notebook
Lenovo g550 turns off when power supply is disconnected ,battery shows fully charged
Replace the battery, it's faulty.
Batteries only have a useful life, then they have to be replaced. Sounds like yours is doing like the ink cartridges, where they register as being full of ink when actually there is no ink in the cartridge.
May 18, 2012 | Lenovo G550 Notebook
Lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Feb 01, 2012 | Lenovo G550 Notebook
How do I turn on numlock in lenovo g550
G550 The keyboard has a separate numeric keypad. To enable or disable the numeric keypad, press the Num Lock key.
Reference user manual: http://download.lenovo.com/UserFiles/UserGuide/en/User's%20guides%20and%20manuals/G450-G550/Lenovo%20G450-G550%20User%20Guide%20V1.0.pdf
I do this for fun & 4 thumb feedback, not $$$$
Jim
Oct 04, 2011 | Lenovo G550-29583AU Notebook
I have Lenovo g550, bought in April Since a few days ago, I hear beeps every now and then, during the work. These beeps sound exactly like those two before booting up *always is 4 beeps in a raw, then a...
If these beeps aren't while booting up, then there is software program notifying you of something. It could be a system beep for just about anything and isn't easy to find without hands on.
You can do a little research on your own - checking your installed programs for notifications.
You can open your event viewer where everything your system does is recorded minute for minute (tedious but works) Problems show with either a yellow triangle with a ! in it or a red button. The program gives a short description - not detailed but it could give you an idea where to look.
It's difficult to assume anything with the limited information given but suffice to say, if you're in windows, it's not a boot issue.
Oct 05, 2017 | Lenovo G550-29583AU Notebook
Iam using Lenovo G550 today system is not booting screen totally blank all Led was on but system is not booting screen totally even hardisk, posser also not responding let me know what is the exact problem
Hi and welcome to Fixya!
If the issue with your machine is just caused by a glitch, try to do power drain.
1. First shut down the machine and unplug the adapter and take out the battery.
2. Press and hold the power button for 10 seconds.
3. Then put back the battery and plug back the adapter. Try to turn on the machine normally.
If this does not solve the issue, it could be caused by a problem with the motherboard. If your machine is in warranty (or even if its not), contact Lenovo warranty support on this number - 1 877 453 6686.
Hope this helps!
Takasashi
Jul 13, 2011 | Lenovo G550 Notebook
I buy a lenovo g550 laptop in 10 jan 2010,it battery work nicely and give 3.30 hour backupup to 9 jan 2011,but after one year that is 10 jan 2011 it give only 50 main back up....it discharge very fast that...
Hi Faiz,
Feb 06, 2011 | Lenovo G550 (2958ACU) PC Notebook
I ve problem when i try to shut down my lenovo G550 2958 laptop.Pls help...
Hi knabeela86,
What is the problem that you are encountering when shutting down the computer?
Try also to perform power drain it might help.
How to perform power drain:
1. Turn off the computer completely.
2. Take out the battery from the system and remove the AC adapter.
3. Press and hold down the power button for 10 - 15 seconds.
4. Put back in the battery and AC adapter then try to power on the computer.
Hope it helps,
Thank you for using FixYa.
Dec 17, 2010 | Lenovo G550 (2958ACU) PC Notebook
I have lenovo g550 notebook and i have downloaded bluetooth software from www.customersupport.lenovo.com it is coming as preparing to install and is telling that no bluettoth device was not found can u...
Bluetooth is an optional component when you purchase lenovo g550. Make sure you have requested for the bluetooth device when ordering the notebook. Please refer the link below for your notebook specification. You will have to get back to Lenovo servicecenter or customer care to get it fixed with the bluetooth device
http://www.lapspecs.com/wiki/lenovo+g550
Hope this helps
Regards
Sherbaz
Aug 06, 2010 | Lenovo G550-29583AU Notebook
Lenovo G550 PC Notebook Logo
197 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
