Konica Minolta Bizhub Press C6000 Copier Logo
Posted on Jan 25, 2013
Bizhub Pro C6000 says please replace the saddle stitcher trim receiver
My Konica Minolta Bizhub Press C6000 Pro. How to remove error code C2402 in Bizhub Press C6000 Pro please?
Question edited for clarity and toss in some CAPS.
Question moved to category.
Error Codes > Konica-Minolta > bizhub 500 > Code C-2402
Printcopy.info https://printcopy.info > code=C-2402
Code: C-2402; Description: Erase lamp (EL) connector slip-off abnormality. - When EL turns ON before starting an initial charging, EL abnormality has been ...
Missing: press ‎C6000 ‎Pro.
Bizhub PRESS C6000 error codes
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Aug 7, 2013 - 1. Check the connection between the rear side connector of the fusing unit and the main body side connector, and repair it if any abnormality.
My konica minolta bizhub c6000l has error c3912, and the machine is warning up for long time and not print. how do i fix this problem?
2. Failed fuser lamp(s).
Check continuity of the three upper fuser lamps L2, L3 and L4. Check the operation of the three upper fuser lamps in the Service Mode by following the steps below. Replace failed fuser lamp (p/n A03U M31E 12 for bizhub PRO C5500/C5501/C6500/C6500P/C6501/C6501P/C65hc and p/n A1DU M31E 00 for bizhub PRESS C6000/C7000/C7000P/C70hc/bizhub PRO C6000L).
a. Press Utility/Counter.
b. Press "Stop 00" "Stop 01" to access Service Mode.
c. Press State Confirmation.
d. Press I/O Check Mode.
e. Enter code 45 using the numeric keys.
f. Press Access to enter multi mode 11 (L2).
g. Press the START key. Verify the lamp comes ON.
h. Press the STOP key.
i. Press "C" key to enter another multi mode.
j. Repeat steps 6 through 8 for multi mode 12 (L3) and 14 (L5).
I have a Konica Minolta 1052 Bizhub and got an error C-1244
saddle stitcher section is in op. get a tech out to look at it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub pro c6000
Did you made all the steps from the service manual when you changed the drums and developers?
Bizhub pro c6000
Check that all of the charge wire assy.'s are properly pushed in all the way in particular the cyan also ensure that the bolt at the top of the middle section is tight not just the one on the left side when closing the upper middle section housing drums and transfer belt.
I am getting a Jam code j-7107. although there is no paper jam
Check the saddle sticher section doors and sensors
Receiver exchange error message
replace the trim waster with a new one
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Code d'erreur C3505
Fusing error have tech look at and reset
8helpful
3answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
