My mazda mpv wont start to coldout tryed boosting still wont start what can i do no garage to worm it up
Pull the battery, if it freezes it will be wrecked, take it to be tested or charged; re-install same battery(if fixed, charged) or new battery, if not able to fix old one. Away you go
One time for me, it was the main fuse(80 amp) in the fuse block(box) under the hood on the passenger side - the guy who boosted me blew the main fuse so nothing worked. Mazda dealership carries those fuses
SOURCE: My Mazda MPV TDI looses oil frequently
its almost normal.i would switch to a high milage oil at the next oil change.u also might want to change the pcv valve.
I had the same thing happen to me...fans would run even when car turned off. Was the thermostat. Got one with high temp-92* I think, it did the trick!
SOURCE: 1989 mpv mazda does not start on cold mornings and
I'm assuming the engine cranks with the starter but does not start and run.
check the operation of the cold start injector. This is a separate fuel injector that injects fuel into the intake manifold to help richen up the mixture for cold starts. It operates on a timer that is linked to a sensor that measures engine coolant temperature. Once warm or the timer runs out, the cold start injector is turned off. Other things to check:
Fuel pressure too high (floods engine through cold start injector), engine coolant temp sensor or intake air temp sensor is stuck at full hot (doesn't allow enough fuel for cold starts), fuel injectors are leaking (floods engine with fuel).
