Its not printing black or dark
The main cause of light print is a bad set of charge and transfer rollers. These rollers are used to put a charge on the paper and transfer the toner to the charged paper. When the rollers get worn out they can not put the proper electrical charge on the paper so the toner does not stick to it as it should. One roller sits under the toner cartridge and on is on top on the cartridge. If you pull out the toner and look inside the printer you will see the transfer roller and if you start to close the lid with the toner out you will see the charge roller come into view. Here are pictures of each one. Transfer roller first.
These rollers come in the preventative maintenance roller kit. This kit is available at the following link. The kit also comes with the pickup rollers.
http://www.ccl-la.com/catalog/product_info.php?products_id=301
SOURCE: Lexmark t642
I too ran into this problem. Printer is about 2-1/2 yrs old.
Using it as a network device. I updated firmware from
a Mac OS X computer on the network.
a. Uploaded the firmware by going to lexmark site.
Do this first in preparation of upgrading firmware.
Follow instructions to get firmware update.
b. power cycle the printer (turn off & unplug power from unit)
c. power printer and turn switch back ON.
happily printer stays alive long enough to upload the new
firmware update.
d. Log on to your printer via a computer on your network
Open a browser, address will be your printer's IP address
or dns name. ex: http://192.168.1.3 (note: if you password
protected the account, you will need that info)
e. Follow menu to Configure -> Update Code where you will
"browse" to the file on your local computer (ex:
LSSTN234.FLX) and then hit the FLASH button
SOURCE: lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
SOURCE: Lexmark T642 - print is very light
take the cartridges out and clean the spot they go into then clean them off also
SOURCE: Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
