SOURCE: Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
SOURCE: I wish to read the total copy count on Xerox
You have to print out the meter report.
The System Data list will be printed with the following information:
SOURCE: i use xerox M15i printer.i used xerox pe 16
I believe you are refering to the Xerox XD Pro 16. And this machine is the M15i.
If this is the case, the two machines are very different, driven by their own software. They operate different.
If this is not the case I would be interested in hearing this again.
SOURCE: bad power supply/capacitors Xerox M15i WorkCentre.
Hi
I have to make some assumptions here. Since you know that there are bad capacitors on the power supply board then you'll need to get replacements. When you go to order these make sure you order the exact part i.e. .5ufd, 100vDC, 70temp and 57hz frequency. This is a poor example but ordering the exact replacement part is very important. There are hundreds of places to get the caps online. Now to replacing these. If you have enough electronics knowledge to determine if these caps are bad then I have to assume you can replace these fairly easily. This will only require simple tools i.e. anti-static 30w watt soldering iron, anti-static desolder device, anti-static wrist strap with known good ground. Appropriate solder. Good luck
SOURCE: where to find a driver for scanner Xerox
While Xerox has not made one specific to the Windows 7 OS, I have had customers utilize the Vista 32/64 bit version which has had some success.
Try this link:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WC_M15i&Xlang=en_US&Xcntry=USA
Qapla!
