Was on line when power went out (snow storm) and I lost dial tone on land line phones which returned after I unplugged modem. When power came back on I was able to get on line for first time or two and now pc says no dial tone. External modem checks out ok on other pcs but still says no dial tone on e machine...even when a live phone line, which I know has a dial tone, is plugged in. Otherwise, computer operates fine. What can I do next?
SOURCE: Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
SOURCE: No Dial Tone on phones or modem
possible its in your telephone wires, try check it with a liscensed technician of your telephone company.Maybe the wire threads are broken or even worn out.
SOURCE: cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
SOURCE: Modem Problem?
In order to really test your modem you need to call more than just 1 (your ISP's) number. If you are not getting 56k connects, you should try your modem with other local/toll/toll-free numbers. This is a list of some toll-free numbers, the 3Com "Line Test" Number (a toll-call), and links to various ISP local access number listings Setting up an account with a Free ISP is another way you can test and isolate modem/ISP problems.
1-847-330-2780 - USR Linetest number - this is a toll call; if you log-in as "Line Test" with a v.34 modem, it will attempt to determine if your line will support 56k connections.
1-847-330-4569 - US Robotics' V.92 Test number - this is a toll call; the server is a 3Com Total Control HiPer ARC running V.92 server side code that supports PCM upstream.
The following numbers use toll circuits but are free to the caller (as long as you don't log in):
1-800-245-3828 - (Canadian weather BBS)
1-800-590-4857 - (IBM Global network access # x2 and V.90 3Com Server)
1-800-784-3638 - (Netcom - supports V.90)
1-888-861-8490 - (MCI/Worldcom))
1-888-245-0113 - (AOL access x2)
1-800-716-0023 - (AOL alternate access)
1-888-296-3892 - (AT&T Worldnet accessV.90,x2)
1-800-638-1483 - (GTE Net access - V.90/K56Flex Ascend Server)
1-800-572-1959 - (Compuserve V.90,x2)
1-800-350-6885 - (Earthlink - V.90,x2)
1-800-853-7921 - (Earthlink - Flex)
1-800-534-7097 - (Earthlink - Flex)
1-800-304-4226 - (Shore.net - Flex)
1-800-320-4509 - (Ascend 56KFlex test line)
1-800-779-2966 - (Used to be MCI)
1-800-846-7562 - (Gateway BBS)
SOURCE: Phone line fault
Your modem card got bad. Replace your modem card. this is a common problem.
Good luck.
