Question about Gateway Computers & Internet
Gateway pa6 fan problems
I replaced the CPU fan because I couldn't see or feel it working. Now, SAME PROBLEM!! After some investigation, I found the following; When I power up, both fans will run for approximately 10 - 15 seconds and then stop. Anyone have an idea of what I might try next? [Laptop is running on XP]
  • Dean1937 Jan 27, 2013
    I have now found that sometimes, when powering up, both fans will runrunning
    'cont;'both fans will run and with laptop on its edge so I can watch the fan, CPU wil run maybe for a couple of minutes and then shut down but the fan near the HDD will keep running. Another strange thing is that the 'Num Lock' wil stay lighted for 1/2 way thru the 'XP log on screen' and then 'go out'. And yes, it is set to "ON" in the BIOS! Anyone else confused about this problem like I am?? That is not a big deal since when 'booted up' hitting the Key will 'fix' that problem. Just wondering if these 2 problems might be related?
  • Gateway Master
  • 5,599 Answers
Old post.
odd symptoms.
the OP never once told the full story
what works good and not.
XP runs? surely it can, 0.4% 2016 run XP world wide and way less now 2018, due to virus magnet status.
do not run XP , and the fan is not XP job.
BIOS runs the fans.
if the PC runs at 56C or so and the fans slow that is normal
The bios only speeds up facts at start,
the slows them and monitors CPU heat and GPU heat
if they rise too high the fans spin up.
this is how all PC run
my fancy desktop has 600rpm fans right now, due to cool running CPU. 4 pin fans can do that magic.
The reason for the fast spin up is easy to learn turned on fresh.
the PC ASSUMES the chip are hot.
say PC parked in a trunk at 120F
the you go indoors and turn it on
so to be safe, it runs them fast (like at BIOS machine code instruction 1 or first. it spins them up then watches CPU temps live. this can take a few seconds to do a scan, see a TREND
if the trend show low, temps, it then uses a PWM fan table in the BIOS, and set the fan speed off that hard coded table)
get that?
now say PC was hot turned on then it slows only if fast fans speeds can lower the CPU temp
then rule 2 and 3 on BIOS CPU temps
if bios does not like say 80C it can turn itself off.
if failing to do that, say fan is dead, learn that ALL CPUs from P4 up
can turn them selves off they HALT.
ALL AMD and intel CPU do that.
ok?
and did you really clean it
is the RAD clean.?
http://www.pcdied.com/overheated.html
Posted on Sep 27, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: cpu fan starts then stops
I figured it out....... the cheap ass cpu fan went south
Posted on Jan 12, 2008
Anonymous
SOURCE: cpu fan control wont stop running
I had the same problem. Luckily, I found the "Sony Fan Control Driver" here:
http://esupport.sony.com/perl/swu-download.pl?template=EN&upd_id=170&os_id=6,7&mdl=PCVRX450
Runs nice and quiet now!
Posted on Dec 28, 2008
Anonymous
SOURCE: Problem with mobo upgrade ... From Intel CPU to AMD CPU
OK, here's what I did in the same case: After installing new motherboard, I booted from Windows XP CD and typed "R" to run the Recovery Console. I went into Windows\System32\Drivers and deleted every file whose name started with "Intel". Then I booted windows normally, it loaded and happily detected the new hardware (including new CPU). If you do not have windows CD, you can try booting in safe mode (it worked for me) and delete the files. But this might make the new hardware detection a bit less "clean", though it should still work OK.
Posted on Jul 18, 2009
Data-Net
  • 37 Answers
SOURCE: Acer laptop fan stops working after 5 seconds
Check the Bios and see if the Fan is set to a certain temp or on all the time. there's a chance if it's set at a certain temp that the temp tracker (thermometer) may be borked and not reading properly. Remember, turning the fan on all the time will use up energy so your laptop will not last as long on batery life.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_d799f810c7212a78
Posted on Aug 24, 2009
Anonymous
  • 23 Answers
SOURCE: I need a replacement Gateway ML6714 cpu fan
Try your luck here.
Posted on May 12, 2010
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
My gateway laptop automatic power off ? way
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 26, 2012 | Gateway Computers & Internet
Gateway m255 laptop cpu fan wont let me boot up
open your laptop up and make sure the fan cabels are in correctly if not push them in if that dosen't work get a new fan for it
Jun 15, 2012 | Gateway M255-E Notebook
Cpu overheats
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 25, 2012 | Gateway GT5012 PC Desktop
What does the fan look like for HP m7680n i need to replace it. at boot msg, fan failed press F2 to continue etc.
  • With the power off open the case. Generally it is the left panel that will slide off after you remove the screws in the back.
  • You will see the fan setting on top of the CPU heat sink.
  • Turn on the computer. That fan should run.
  • If not, turn off the computer, remove the fan and take it to a mom & pop computer store and ask for a replacement. Shouldn't be very expensive.
  • If you don't feel comfortable do what I suggest, take the tower to a mom & pop computer store and they can do it. There might be a minimal charge in addition to the fan.
I would not run the system very long (minutes) until the fan problem is resolved as you can over heat the CPU and ruin it.
I do this for fun & 4 thumbs not for $$$$
Jim
Oct 05, 2011 | HP Computers & Internet
On power-up there was a "CPU overheated" message and now nothing works. Is there a high probability that the CPU is fried?
Quite possibly. You will need to remove the fan and heatsink from above the CPU to find out if it's just fried the CPU or cooked the motherboard (mobo) too!.
Replacing the CPU is not too hard, you'll need a little thermal paste, replacing the motherboard can be a pain unless you're techy.
Good luck
Aug 26, 2011 | Gateway Sb-4100-B PC Desktop
Ijust replaced the cpu fan and now the computer won't boot - it just flashes the gateway logo
make sure that the power reqs for the fan are the same as one you replaced and make sure that the new fan is the same prong (3 or 4). Also make absolutely sure you plugged the new fan power supply inti the CPU fan slot
Apr 15, 2009 | Computers & Internet
Fan not working and the laptop shuts down
Clean on Replace the fan. It is getting to hot w/o it and you are overheating the CPU.
Apr 02, 2009 | Gateway M6307 Notebook
Gateway Laptop overheated and stopped working.
Usually when the laptop overheats the CPU shuts down, and after it cools down you may be able to power it up again, unless the CPU has failed.
If you are able to get the laptop working, get the fan replaced, if it laptop doesn't boot up then there is a serious problem (most likely a costly one).
Jan 01, 2009 | Gateway Computers & Internet
Computers & Internet Logo
217 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
