Question about Beko Wm & Wma Models Washing Machine Motor Carbon Brushes
Yes, It seems that the motor seems to be the fault
Check this link: brushes
Posted on Jan 25, 2013
SOURCE: how to reset or unlocked the beko washing machine timer
Try unplugging the machine for 5 minutes, if that doesn't reset it you likely have a defective main control circuit board.
Posted on Feb 07, 2012
SOURCE: Machine won't wash but will spin
If your washer doesn't agitate, check these:Lid switchMotor couplerBeltsClutchDrive motorDrive pulleysTransmissionAgitator good-day !
SOURCE: beko not draining and spinning
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Also must check water level device,if You do not know what is this or where is on machine then call a service.Maybe the hose is precipitate from device.
Posted on Apr 20, 2012
There is a capacitor in the top of the machine to check/ replace and connections from the timer to check.
Posted on Apr 21, 2012
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
Posted on May 22, 2012
