Question about Nikon Coolpix S6100 Digital Camera
Stuck zoom button on Nikon Coolpix S6100
The zoom button on top of the camera won't move with my finger pushing it. I have taken very good care of the camera, has NEVER been dropped...
    Genius:
  • 1,019 Answers
Even though you have taken good care of your camera it does not mean that parts wear out, switches just go bad after use. Your camera will require repairs at a shop to correct this problem. This is NOT a user fix.
Posted on Jan 25, 2013
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: My camera will not take a picture unless lock button is held
Had this problem two weeks ago. On the road to recovery, changing the purpose of the function button seems to have helped me - <Menu>, <Set-up1>, <Controls>, <Func.> Change chosen option away from the top one (User Setting). I found the third one down with the flash symbol least confusing. Then <Set> and <Menu> button to escape from the menus.
Having done all this the camera will take pictures again without pressing the lock button. However, I'm not convinced the func. button works as described in the manual. Hope this helps?
Posted on Feb 10, 2008
97F350diesel
James Brooks
  • 1326 Answers
SOURCE: I cannot activate Nikon Coolpix S210 (problem with ON/OFF button)
had a similar issue with my Pentax, it would power on and power back off. Tried playing with it for a while and it never recovered. Chances are its time to replace it. These new electronics are jam packed with lots of mini moving parts and are prone to excessive wear over time. they're are no servicable parts inside them unfortunately. I would try ebay for a reasonable replacement camera.
Posted on Aug 06, 2009
Anonymous
SOURCE: flash doesn't work on nikon coolpix l12
I actually just fooled around with mine because it was doing the same thing. It will only flash in the scene mode, but not the normal quickshot mode. i noticed under the camera symbol on the screen said BSS and i went into the menu and clicked on BSS and turned it off b/c it was on and that worked finally.maybe u can try it, if its the same situation.
Posted on Aug 07, 2009
  • 102366 Answers
SOURCE: nikon coolpix L18 lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
19messiah65
Jesus Bryan Soriano
  • 230 Answers
SOURCE: COOLPIX P80 Digital Camera: my nikon camera's lens is stuck...
The lens of the camera can be retracted by mechanical means driven by gears thus sometimes likely to become misaligned or jammed. Please do not attempt to force or push the lense as it might cause serious damage, the best thing to do is to have it fixed by your authorized local repair shop and have the mechanical components checked.
Posted on Jun 24, 2010
How can i use flash in s6100 camerah
Isn't that a Nikon camera? Nikon Coolpix S6100?
It has a built-in flash, you can activate it using the information provided in the camera manual. Nikon COOLPIX S6100
You can use it as primary source of ligth when shooting indoors or doing night portraits. You can also use it as a fill light. Read the manual.
Oct 15, 2014 | Canon Cameras
How do I clean Lense on a Nikon Coolpix S6100 7X Zoom 16MP
you can not clean at your self. Use dry cotton or ear buds for cleaning the lens front side. After that if its still there then use compressed ai in surrounding the lens. After that if the spot still there then you need to visit service center for cleaning the lens internal side.
Aug 10, 2012 | Nikon Coolpix S6100 Digital Camera
Free driver for nikon s6100
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac and Windows Photo Gallery on Windows, and Picasa on both.
Dec 07, 2011 | Nikon Coolpix S6100 Digital Camera
Cannot zoom; cannot push menu button and access other shooting modes; cannot push '&gt;' button and review taken pictures. basically, it will not allow me to change anything via buttons on rear of...
Has this camera encountered any water or moisture? Sounds like the Ribbon cable to the
option panel is either loose or has been compromised. It could have come loose after a
drop or hit, compromised cables are results of water damage or moisture damage.
Feb 01, 2011 | Nikon COOLPIX S610c Digital Camera
Nikon coolpix l20. I cannot turn the camera on.
I HAVE THE SAME PROBLEM, DOES ANYBODY KNOW HOW TO SOLVE THIS
Mar 15, 2010 | Nikon Coolpix S550 10 Megapixel Digital...
Nikon Coolpix S6100 Digital Camera Logo
122 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
