Question about Lexmark Z645 InkJet Photo Printer
Lexmark z645 does not print blue on test page with two new cartridges
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Posted on Aug 16, 2007
Thomas F. Schneider
  • 2715 Answers
SOURCE: my lexmark doesn't print
Clean the printer heads .
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Jan 18, 2009
Anonymous
  • 31 Answers
SOURCE: Lexmark X2580 won't print after cartridge refill
I know this is something that you may not want to hear... I used to work for Pitney Bowes fixing postage machines.. these machines have inkjet printers in them. If you use refills other words ink not from the manufacturer it will cause you problems. I know that it might work a few times without problems... but I have seen it first hand at Pitney Bowes... If you don't use the manufacters ink it will destroy your printers. In your case go back to using the Lexmark cartridge... see if that solves the problem. Which it very well could work off the Lexmark brand again. Printer manufactures do this on purpose you have to buy their ink! In any case good luck.
cdixon18
The Man Inside the Machine
Posted on May 11, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: The Lexmark Z645 will only print blue, yellow and black
    Hello. The nozzles of the color cartridge may need cleaning since it's doing the same thing on two different printers. Here's an article in the Lexmark website on how to properly clean the nozzles of the cartridge. Just click on this link: http://bit.ly/9wzuAL . If it still won't work, try your old color cartridge if you still have it and still working. If it works properly with the old cartridge, maybe you got a defective new cartridge. Hope this helps. Good luck!
    Posted on Mar 23, 2010
    SOURCE: I installed new cartridges in my X2550 Lexmark I
    it depends on the error message why the test page won't print. If it just won't print at all, try to reseat the paper into the printer and turn off/on the printer then try to print the test page.
    If it doesnt, then turn off the printer, remove cables. And then press and hold the power button on the printer for 5 seconds . Reinsert cables and turn on the printer and print the test page anew....
    Posted on Jun 04, 2010
    Testimonial: "his was a solution that had tried but not quite the ame. It worked the first time. Thank you vey much as I haved been foolin with this for several days without getting iy yo work."
    I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
    Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
    May 08, 2011 | Lexmark Z645 InkJet Photo Printer
    Mar 23, 2010 | Lexmark Z645 InkJet Photo Printer
    I have a lexmark z645 printer and i downloaded the latest print driver for it. It will print a test page and it will print from microsoft publisher 2007, but it will not print from microsoft word 2007...
    Ha ha, simple my dear. Please go to control panel / printers & fax or devices & printers ( according to your Operating System & set Lexmark as your default printer.
    Feb 10, 2010 | Lexmark Z645 InkJet Photo Printer
    Printer not printing in color; new cartridge, tests are fine
    Check your printer settings to make sure the print in b & w box is not selected. Hope this helps.
    Feb 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
    Lexmark z845 ink refill problem
    i need adisk to install z645 printer towindows vista couputer
    May 08, 2008 | Lexmark Z645 InkJet Photo Printer
    After changing cartridge, printer will not print, z645?
    First... check to make sure you removed the yellow tab from the new print cartridge
    put the ink cartridge back into the printer
    click Start
    click Control Panel
    open Printers and Faxes
    click (or double click to open) your printer icon
    click on Printer menu
    click on cancel all documents
    Then try printing again.
    If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
    Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
    Printer Problem
    you should go to your LEXMARK solutions center either on your desktop or in your start menue and open the maintenance program and run the alignment. select the best arrows and enter them where indicated. this should help clear up your problem with a new cartridge
    Oct 08, 2007 | Lexmark Z645 InkJet Photo Printer
    Printer won't print the BLUE color.
    The cartridge may have worked perfectly when you purchased it, but something in either the electronics of the cartridge or of the printer may have failed. Is this cartridge new or recycled? If recycled, something may have been damaged during refilling that happened to pick that time to fail. Replace the cartridge. If it comes back, the cartridge was faulty. If not, then most likely the carrier is bad or the cable is loose. Worst Case Scenario, the main board. But Im betting on the cartridge.
    May 29, 2007 | Lexmark Z645 InkJet Photo Printer
    Lexmark Z645 InkJet Photo Printer Logo
    90 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Ekse
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
