AT&T 1818 Corded Phone Logo
A
Anonymous Posted on Jan 24, 2013
On wall phone my receiver keeps falling off the phone I have a rubber band around the top of the phone so it will not fall out of the cradle.
The white tag on the bottom of the phone has Y051012026398306. I just bought this phone today I can't find a product # on my user's manual. Please help. Thank you
1 Related Answer
Anonymous
  • 211 Answers
  • Posted on Jun 15, 2009
SOURCE: Small peice broken on MLS12D
These phones are discuntinued by Avaya. Try getting replacement phone. Call 1800-980-ivds
Coil nailer
Make sure that the check band (black rubber band) is installed around a series of holes drilled into the lower part of the cylinder. This band can fall out of place when installing the cylinder ring. Good luck
Porter cable roofing nailer piston won't retract
Could be the check-band around the cylinder. Easy to check. Remove the head and pull out the cylinder. There should be a rubber band covering a series of pin-holes drilled into the cylinder. Usually the band will fall out of place or break. Use any rubber that will stay in place to cover the holes. Good luck.
I'm having trouble keeping the chains on my John Deere Tractor. I put them on exactly how the diagram said. They seem pretty tight but they keep falling off when I get out there during snow removal. ...
you need to make shure the chains fit the tire snug and then you need to put a rubber tension band (they usually don't come with the chains) you can get them at a walmart or auto parts store, about $2 for 2 of them and come with little s hooks that you secure to the chain, instructios are on the package, the rubber band you put on the chains on the outside of chains and it keeps tension on the chains so they won't be lose and fall off. hope this helps.
2helpful
We purchased this phone and on the box it claims that it can be mounted on the wall. It CAN NOT be mounted on the wall as the receiver falls off it's hook. There were not installation instructions about...
Often there is a handset catch near the top of the cradle that must be reversed to allow the handset to hang in the cradle when installed as a wallphone. Typically the phone is initially setup as a desk phone, if this catch piece was reversed it would interfere with lifting the handset. Some models have a screw holding this piece in place, some just slide into cradle.
1helpful
Missing Rubber Stoppers on Kinderkraft Crib Dreamer No. 305
You can probable just put a nail or srew in for now!
Here is the 800 number for kinderkraft. They have a website but it doesn't appear to be working. 1-800-822-6748
e-mail [email protected]
http://kinderkraft.com/main.htm
1helpful
Model 29265 trimline phone handset falls from cradle
push the handset hook up and out with your thumb,turn it 180 degrees,and replace it in the slot on the base. Bridrijo D. Howell,Bermuda
3helpful
2answers
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Wall mounted ge phone
Problem solved. The little black square was supposed to be put back upside down...This allowed the hand held piece to hang on.
thanks
2answers
32" Magnavox TV keeps turning off?
youve most likely have a thremal issue that causes the set to **** down when operational temperature is reached possibly a regulator tarnsistor .
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
