1999 Jeep Grand Cherokee Logo
Posted on Jan 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I reset my Factory Alarm on my Jeep it wont run
My 1999 jeep grand cherokee horn started blowing and i had to put the fuse to stop it now my jeep will run for a few minutes then shut down or it wont start...
  • 2 more comments
  • patrioticbab Jan 29, 2009
    Thank You very much I did what you said and it started right up..
  • mosaicart May 10, 2009
    o.k I do not have a disarming thing! and I do not want to have to jump in my car and drive real fast to get it to stop!
    Every time I open my car door with the key it starts blowing ansd I can not get it to stop without taking out the horn fuse, so how do I fix or take out this alarm and also I lost the unlock key chain I only have a key :-0
  • Anonymous Mar 23, 2014
    TURNS OVER BUT WON,T START AND GAGES DON,T WORK
  • Marco
    Marco Mar 28, 2022
    I did not get a keyfob with my car. Just a regular key
Darrell
Level 2:
Scholar:
  • Expert 118 Answers
  • Posted on Jan 28, 2009
Darrell
Expert
Level 2:
Scholar:
Answers
118
Questions
0
Helped
74821
Points
425
Alarm Module Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
  • Darrell Feb 01, 2009
    thanks for the comment if ya need any more info let me know always waiting to help a brother in need DB
  • Donna
    Donna May 19, 2022
    I have a 05 keep grand Cherokee couldn’t get part to fix because they no longer make it and they wouldn’t program a used part but got car running but can’t get lights to stop flashing
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Dec 12, 2008
SOURCE: 1999 JEEP GRAND CHEROKEE LAREDO
i have a 95 jeep grand cherokee lerado from time to time my alarm goes off i dont have a remote 4 my alarm but i found out that if you put the key in the driver door and unlock it. it will reset the alarm!!!!!
Jeep Grand Cherokee Diesel CRD 2.7. Where is the alarm fuse on it please?
Question edited for clarity.
Question moved to model category.
The security alarm and engine immobilizer are functions of the Body Control Module (BCM) and the ECM. You can't just pull fuses. When the battery goes completely flat, or is disconnected, you just need to reset the Security System which is done via the Remote Fob.
https://www.google.com/search?q=jeep+grand+cherokee+security+reset
Jeep Grand Cherokee (WJ; 1999-2005) fuses and relay
Fuse Box Diagrams https://fuse-box.info > jeep > jeep-grand-cherokee-wj-...
Here you will find fuse box diagrams of Jeep Grand Cherokee 1999, 2000, 2001, 2002, 2003, 2004 and 2005, get information about the location of the fuse panels ..
I have a 99 jeep grand cherokee 4.7, the alarm went crazy and the wont start. guages dont budge and horn keeps honking and lights flashing. sentry key light is on in guage cluster any help
Sounds like you need to perform a relearn on the anti theft system, it's not recognizing the key if this happens with the key inserted. Might want to look online for a reset procedure for Jeep. GM has you keeping the key in the ignition in the on position for 10 minutes.
How to disable the alarm system on a 1997 jeep grand cherokee laredo
i have a 1997 jeep grand cherekee laredo and am having a problem with the alarm its a factory alarm it whent off and i cant get it to reset i tryed everything i could locking and unlocking the doors i put all new fuses and relays in i even unpluged top dash alarm sensor and body control module and it just dont want to reset and it dont want to run at all how can i take care of the problem
1helpful
Security alarm stays on and vehicle wont start
Sure the door lock is bad maybe. with the fuses in and the doors clsed try the other locks some jeeps only reset with the hatch lock as all the others are worn out or don't detect tha t the door is closed
I have a 1999 jeep grand cherokee. the alarm goes off whenever i open the door if the vehicle has been locked the alarm stops when i start the vehicle i only have a key, no remote any ideas on how to fix...
If ithe alarm is factory when they will have to reset the alarm module with a scanner. If the alarm if aftermarket go to the control module and see if it has a reset button. FOBs (remote) can reset alarm. You Jeep is always set for break-in mode. The FOB sets this when ever the FOB is used to lock the doors. May be bad alarm module - Sorry - Good luck
5helpful
Alarm went off, car wont start. reset switch??
Pull the battery cables, hold them together for 3-5 minutes, this resets the cpu in the car. That should fix it.
Disarm malfunctioning alarm system jeep cherokee 1999
try to find a fuse and take it out it may have one just a guess
1helpful
3answers
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
