Has a squealing sound when starting up top load washer
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
SOURCE: Maytag Top loading Washer, fills but won't stop
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
SOURCE: my pav3300aww top load maytag washer squeals when
sounds like a brake issue, youll need to replace the brake to stop the squeak. problem with this is the brake is loaceted on this machine under a "high tension" spring nad in order to remove and replaceit youll need a specialized brake removal tool. GOTTA LOVE MAYTAG. so the cost to purchace the bake and the tool to do the job may out weighthe cost of someone doing the job for you..just like your car thought its a sqeaky brake, JUST ANNOYING to listen to but no real harm being done
SOURCE: Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
SOURCE: My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
