I've five wires to my sensor,1 black,2brown,3 black with white line,4 red,and yellow.The Performance chip is supposed to increase horsepower,fuel milege,etc,etc,etc
That product won't do a thing
You don't cut into the manufactures expertise &
start changing things, unless your building a race car
You have an 11 year old vehicle
I ask- is it even conceivible to increase mileage,
horse power etc,etc if it was brand new & on a street
driven vehicle? No
Every week we get several questions like yours &
not one product has instructions,that's odd isn't it
Who are you asking these questions to & how would
any but a handful of old time car guys even know what
your referring to?
SOURCE: IAT and MAF info
I have the same "chip" (really just a resistor). It should be the wire harness that clips into the lower box of the intake. I believe it is a green and a black wire. Just unclip it and slide the end of the resistor into each wire prong. Then tape the heck out of it. I put a rubber cap over mine then electrical tape. Works like a charm
SOURCE: 2006 Civic EX IAT wiring?
what are you trying to do? wire in a resistor to make car think it is colder and give you more fuel?
Save your money, the chip is a ohm resistor at Radio Shack for under $2.00. It splices in to you IAT wire harness located at the intake tube between the air filter housing and throttle body.
Problem with this system is, that you can not adjust anything and have to run a constant 91 octane just to make sure you do not have a Detonation. The ECM will catch the Detonation from the knock sensor and compensate for it by retarding the timing which in turn lose of HP till next start up.
If you like and don't mind the check engine light on once and awhile, you can do the same by just disconnecting the IAT wire harness which give the ECM a 0 resistance thinking it's -20 out side and turn the timing up and lengths the injector pules.
When i was running a Nitro in the Toy before i sold it, i had installed a 10K ohm Potentiometer which you can buy at radio shack for under $5.00 i believe, I just spliced it in to the IAC wire harness so if i wanted to play with the Nitro I'ld turn the resistor up making the engine think it's 185 degrees F and would ****** the timing so i would not hurt the engine. But if i wanted to get more timing i would just turn the knob to drop the resistance to get more time since the engine thinks it's -20 out side.
Hope this helps. Keep me posted if you need more info. Best thing is to do a dyno tune and you can change everything right down to the Shift points.
SOURCE: LOCATION OF -ATC(MAF/IAT) & CTS SENSORS-2007 nissan frontier 4.0
maf is mass air flow sensor, it is on the air filter box, iat is intake air temp sensor, should be in the tube from the air filter box. don't know what atc and cts are sorry. best of luck
