It has a new battery in it and everything i was downloading music on it and it just went blank
SOURCE: iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
SOURCE: IRIver IFP700
It might be because you do not have sufficient administrative privileges for your user account. That is why mine wont work.
SOURCE: iriver H10 "System files missing".
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
SOURCE: iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player
The
UMS trick is a great thing to know how to do. With it, you can transfer
music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
For 20 GB MTP Models
For UMS Models
UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
SOURCE: iRiver Music Manger not recognizing iRiver player when connected
OK, this problem was driving me almost to tears with frustration but have managed to bodge-solve it so hope this helps!
Right click My computer and select Properties.
Click on Hardware tab.
Click on Device Manager.
Hopefully there is a yellow question mark symbol against Iriver T30 listed under other devices or portable devices or something.
Right click this then select Update Driver.
Tell it that you are going to manually update the driver yourself.
Eventually you will have to select what type of device it is - select portable device.
Now click on MTP device and click next to install the driver.
Hopefully now it is recognised by XP in My Computer....
Good luck
H
