You have already deleted it? "threads"? Try Revo Uninstaller freeware at : http://www.revouninstaller.com/revo_uninstaller_free_download.html Run Advanced mode. If you have uninstalled it , Revo may not see it now.
SOURCE: Uninstalling Nero 7 From My PC, Running Vista
go to this link and download the nero 7 clean tool - http://www.nero.com/nero7/enu/Clean_Tools.html - then try reinstalling nero 7 essentials version - make sure you use the nero 7 essentials serial number. hope this solves your problem.
SOURCE: Unable to uninstall Nero-
Try reinstalling nero, use the complete option if there is one.
Then go to download.com and download a program called CCleaner (it is a great program for cleaning out internet history and un-used files safely)
You will see 4 tabs on the left 1. cleaner 2. registry 3.tools 4. options
First at the bottom from when it opens up you sre in default cleaner, analyze and when done run cleaner (note you will have to run cleaner twice probably).
second click registry then at bottom scan for issues, when done select fix selected issues (when the pop up appears select no you do not want to back up the registry) next pop up select fix selected issues.
Third select tools, find nero in the list of programs and remove using CCleaner's remove tool.
This should fix your problem.
SOURCE: nero 7 unistallation fail
Download the nero clean tool from here...
http://www.nero.com/eng/support-nero7-tools-utilities.html
Then re-install the Nero demo again, you have to do this otherwise the clean tool will not work correctly.
Then run the clean tool, this will clear all of the entries installed by Nero.
Hope this helps
Regards
Please Remember To Rate
SOURCE: New hard drive installed' New
Hi ,
Nero 6 is not compatible with Windows 7 64-bit edition . Runs well fine under 32-bit edition .
Regards .
