Cambridge Soundworks BassCube 12 Speaker Logo
Question about Cambridge Soundworks BassCube 12 Speaker
Cambridge soundworks basscube 12
This youtube video shows the exact problem that i had with my subwoofer: http://www.youtube.com/watch?v=Uxr0X0kxVUY My solution was: So i had success fixing this problem with my bass cube which had the same problems as the video above. The problem was with the big 6800uf 50volt rated capacitors on the circuit board. its a simple fix. i bought the replacement capacitors off www.mouser.com. the mouser part number for the new capacitors i bought was: 647-UKW1H682MRD when you replace these capacitors make sure you connect them in the same direction as the original capacitors. easy fix, problem solved, sub works great now.
4 Related Answers
Anonymous
SOURCE: BassCube 12 Startup Problem
same here. happened after moving residences
Posted on Aug 29, 2008
Anonymous
  • 7 Answers
SOURCE: Cambridge Soundworks Basscube 12S only makes pulsing buzz noise
Hey! So i fixed my problem! This is for the BassCube 10
Like i said before i saw that the circut board was burnt near the diodes ZD3 & ZD4, and the resistor R63. Thanks to Deadly1 and BillRad62, i figured it out. The R63 is a 1200 resistor, and the diodes are 15v zeners. I went with 3x 5.1v zeners to replace ZD3, unfortunately Rip-Off-Shack (Radioshack) didnt have 3 packs of these so for the ZD4 i put a 12v and 5.1v. Which exceeds 15, but seems to work without a problem. Hope it helps!
Posted on May 26, 2009
Anonymous
  • 113 Answers
SOURCE: Bass Cube 12 makes loud buzzing noise when turned on !
Hi Ok thanks. I cannot be 100 % sure about this without seeing it but it sounds alot like there is a power supply issue, either bridge rec or caps. Caps are very often very obvious. If you get into it and have a look at what is normally the 2 or 4 biggest capacitors at the start/power supply of the board and see if they are ok visibily. If they are bulged, (often they actually explode and leave paper residue) then those are what need to be replaced. Have a look and see.
If its the bridge rec, it could be 4 diodes, fairly large next to each other or a square component with 4 legs out. Need a meter to test, but i would start at caps first
All the best
Posted on Aug 05, 2009
Anonymous
SOURCE: Basscube 10 dead...need zener and resistor help
The zener diodes are 1N4774, I believe they are one watt. Try 3 watt metal oxide for the resistors. You might as well replace the 6800uF 63 volt main filter capacitors and the 220uF 50 volt capacitors while you're at it. Half the time the heat that cooked your other parts takes them out as well.
Posted on May 26, 2011
Basscube 15 hums only in "Auto" mode?
There is a guy on ebay (edwards electronics) that can repair this amp for around 150.00
2answers
Has humming sound when powers on
You may have a power problem. Check to make sure that your wires aren't touching and not crossed.If this doesn't help try plugging in you sub to different plug could be getting interference electrically in the spot it's in
1helpful
Loud humming noise
this may be result of blown capacitor - have it analyzed by applying strong magnet over the inside speaker , if humming persists, then its not blown capacitor -- the capacitor stores energy, and if that energy is lossed an out in the airwaves, thats the humming effect
2answers
Fuse blows wean speaker is on and burning plastic smell from amp side speakers work fine
the amplifier is drowing too much current, and components are getting heat from that
check your amplifier final stage tempreature,
all so check a short of the circuit.
3answers
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Top Cambridge Soundworks Audio Players & Recorders Experts
Marvin
Marvin
David Shaub
shadow
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
