Cambridge Soundworks BassCube 12 Speaker Logo
Question about Cambridge Soundworks BassCube 12 Speaker
Buzzing squaking sound from speaker that i fixed
This youtube video shows the exact problem that i had with my subwoofer: http://www.youtube.com/watch?v=Uxr0X0kxVUY My solution was: So i had success fixing this problem with my bass cube which had the same problems as the video above. The problem was with the big 6800uf 50volt rated capacitors on the circuit board. its a simple fix. i bought the replacement capacitors off www.mouser.com. the mouser part number for the new capacitors i bought was: 647-UKW1H682MRD when you replace these capacitors make sure you connect them in the same direction as the original capacitors. easy fix, problem solved, sub works great now.
3 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Is there any way to take these apart?
Is it a powered speaker? If not then if you know how to solder ,sure open her up and move around the wires while shes playing and see if you can duplicate the fault. If you dont know how to solder then take the unit in to be serviced as a loose connection inside a speaker can certainly blow out an amps output circuitry. Good Luck
Posted on Jun 26, 2006
Anonymous
  • 1476 Answers
If there are no screws evident on the rear of the unit carefully remove the grill on the front. Usually they are just lightly glued on. Most quality speaker enclosures open from the front and the speaker can be taken out for access to the wiring inside. If you cannot find any way in from the front look for some sort of plug or cover over screws. This could be on the back or under the grill. Sometimes they are covered with plastic covers which match the surface. If you do not have access any of these ways this could be a sealed unit which is not made to take apart. Good luck.
Posted on Jul 12, 2006
Anonymous
  • 113 Answers
SOURCE: Bass Cube 12 makes loud buzzing noise when turned on !
Hi Ok thanks. I cannot be 100 % sure about this without seeing it but it sounds alot like there is a power supply issue, either bridge rec or caps. Caps are very often very obvious. If you get into it and have a look at what is normally the 2 or 4 biggest capacitors at the start/power supply of the board and see if they are ok visibily. If they are bulged, (often they actually explode and leave paper residue) then those are what need to be replaced. Have a look and see.
If its the bridge rec, it could be 4 diodes, fairly large next to each other or a square component with 4 legs out. Need a meter to test, but i would start at caps first
All the best
Posted on Aug 05, 2009
I got a subwoofer jbl 145 wiht my system after one hour of use it make a noisy sound very loo buzzing sound and i have to power it off to stop it!
A very low buzzing sound usually indicates that the speaker is on its way out. Its the small period of time when the speaker is making sound or not.
My model is RX-V665...not sure what the BL stands for... anyway...no sound from the subwoofer. Pull the RCA wire from the back of the receiver and touch it with my finder and you hear a buzz from the...
HI,
first of all select ur sub woofers auto mute (auto power off ) switch to off position.
then connect the mic and calibrate ur system one more time. after calibration select it to on position. u will surely get it work. if need any further assistance feel free to contact through fixya.
ok
2answers
Buzzing/hum website say it's a ground loop or amp issue. Whats the difference and how can I easily fix it?
Hello,the most common solution is to simply replace the subwoofer cable itself. the ground on this cable is the outside of the connector and not the pin in the center and they do fail. You can use any rca cable as a quick test to confirm if the cable is at fault.
1helpful
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
The speaker is starting to buzz during the low
It probably buzzes all the time, you just notice it when it is outputting little volume. Check the cables for loose connections or replace them with other cable as a test.
6helpful
3answers
All the best
10helpful
4answers
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
1helpful
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Top Cambridge Soundworks Audio Players & Recorders Experts
Marvin
Marvin
David Shaub
shadow
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
