SOURCE: Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
SOURCE: RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
SOURCE: TV WENT OFF BY ITSSELF
ours went out on 1-28-08 less than a year old. did anybody else buy theres at walmart.
SOURCE: Power problem on a RCA big screen TV
Even with the tv turned off, the power supply is still active.It's supplying voltages to the microcontroler, that's why each time you press the power button on remote the tv respond by turning on. First check the power cord to be well connected in the power-bar and if it's ok...well the power supply is defective and due to the high risk of electric shock i suggest you to call a technicien.
P.S. I respond here because I don't know why our chat session got disconected.
SOURCE: Black square
If the picture can be seen on the sides of the black square you need to go to the menu and find the text and turn it off
Usually in the closed caption section
